rattle can paint job
Old Mar 2, 2008 | 10:05 PM
Tre-E_Ford's Avatar
Tre-E_Ford
Yeah this might be a newb question and a bad idea, but here i go.
My truck is need of a paint job, not incredibly bad but there are places with some surface rust. What I want to know is if a rattle can paint job(flat black) will hold up for a while until i get more important things done. This will be a fun for playing truck, I agree a proper paint job is in order but for now i just need cheap. What is your opinion of durabak and herculiner, i plan on using herculiner for the flat bed and the lower rockers. Maybe durabak smooth for the rest of the truck. Its for a 1977 f-250 4x4, if that matters.
Thanks
Old Mar 3, 2008 | 10:03 AM
teds74ford's Avatar
teds74ford
I took my time with spraypaint, but a quick job will look just like what it is. I have also used herculiner, and I think it is ok. Probably professional stuff is better, but I am cheap
Old Mar 3, 2008 | 03:41 PM
rg200amp's Avatar
rg200amp
I think that would look real good. but if you want it temporary, i would not use te herculiner, if you want to paint it later, the herculiner is impossable to remove.
Old Mar 3, 2008 | 03:49 PM
Tre-E_Ford's Avatar
Tre-E_Ford
The herculiner will be permanent, the spray will be temporary. Thanks for the advice.
Old Mar 3, 2008 | 09:13 PM
72f250CS's Avatar
72f250CS
tell ya what, I just rattle canned my 58 vw baja. Took some time and prep, but came out fantastic. (I am expecting to dent, scratch, and possibly. roll it, so wanted to go cheap). If you do it right it will last as long as you need.
Old Mar 3, 2008 | 09:38 PM
SuperSnake's Avatar
SuperSnake
Check out this website.
http://rolledon.com/index.htm
Old Mar 3, 2008 | 09:47 PM
icrman's Avatar
icrman
Rattle can is not a cheap way to go. Brushing or rolling would be better than that. And then you color sand the paint. Also you can get a pressure reusable spray can from I think it was Eastwood. You just put in the paint and use a tire pump for pressure, I think thats how it works.
Old Mar 4, 2008 | 05:06 PM
tbm3fan's Avatar
tbm3fan
Eastwood now has a 2K paint in a rattle can. Just saw it in the new catalogue. Hardener is inside and when you break a seal they mix and you are ready to go. Pot life escapes me right now but it was at least 6 hours and maybe a little longer, but expensive at $16-18 per can.
Old Mar 4, 2008 | 10:01 PM
teds74ford's Avatar
teds74ford
Even cheap paint ($3-$4 a can) can get expensive if you do a good job. Trust me, I know The roll on might be the best alternative.
Old Mar 5, 2008 | 10:02 AM
frederic's Avatar
frederic
Durabak is an excellent product. I helped a friend brush over his entire crewcab with the stuff - bumper to bumper - instead of automotive paint. Body, interior, bed, frame, suspension, axles, and so on. All different colors too.
He went with the durabak for three reasons - first, it's really tough and will survive the off-roading punishment he gives his truck often. Second, unlike other bedliner products the color choices are many - many many many. Third, it hides minor body imperfections very well - small dings, scratches, etc. Obviously it's not a body filler but if the surface isn't perfect, you won't know it once painted.
I'll be painting my crewcab with durabak's "white" eventually, I think.
Old Mar 6, 2008 | 07:06 AM
teds74ford's Avatar
teds74ford
More about this please. I saw a can in their catalog, but they said for other stuff like WD40. Could you use thinned paint in it too? Or is there a different one?
dustyroad
13
Oct 21, 2014 08:54 PM
JTyler11688
Paint & Bodywork
Mar 16, 2009 12:20 AM
mooktank
Paint & Bodywork
Nov 3, 2002 09:10 PM
