modifying an external balance flex plate for an internal balance 460. . .
Old Feb 11, 2008 | 11:48 AM
Franken-Truck's Avatar
Franken-Truck
Basically, I used a 460 Lincoln motor that was already ready for a rebuild than my 460 truck block out of my 87 (needed a crank). I have the external balance flex plate (C6) which is in fantastic condition and I want to be able to reuse it on the internal balance motor. . .I'm cheap, I can't help it
I want to know, can I remove the balance weight from the flex plate and use it then? Being careful, say if I have to dill, to drill an equal number of holes on the opposite side?
Thanks
Old Feb 11, 2008 | 06:30 PM
85e150's Avatar
85e150
You're cheap I understand. Be cheap right by not persuing false economies. Get the right part.
Old Feb 12, 2008 | 11:41 AM
Franken-Truck
Yer killin' me Dawg!! It's only $50.00, so. . .I guess. . .
I like your response, can I steal it for part of my signature?
Old Feb 12, 2008 | 01:28 PM
straightsixer's Avatar
straightsixer
Just don't do what I did. There was some confusion when I was ordering and replacing a flywheel in my vehicle. It ended up being the wrong flywheel and there was a horrible drivetrain vibration at speeds, ended up having to remove the flywheel again then taking to a machine shop where they were able to balance the new flywheel to match the balance of the original. If you have any suspicions, spend the $$ to have the flexplate balance checked.
OilfieldTrucker
Aug 29, 2016 04:27 PM
beartracks
Jul 12, 2016 11:20 AM
oldmansimek
Sep 23, 2011 11:50 PM
F350moneypit
Aug 23, 2009 06:29 PM
Superdave
Jun 2, 2003 02:07 AM
