painting leather?
Old Jan 5, 2008 | 04:58 AM
rhino_160's Avatar
rhino_160
painting leather?
hi all, my 2000 navigator has the center console with the lid wrapped in leather. the leather needs to be sanded and painted. i can do both but was wondering if the leather/vinyl paint from JC Whitney in a spray can will work just as well? it says it is a no crack, no fade, no peel paint.. thanks
Old Jan 11, 2008 | 06:25 PM
385seriesHemi's Avatar
385seriesHemi
If its leather Id rather go with a Dye not paint. I know there is Vinyl paint out there but for prepping that you need to clean it damn good and use adhesion promoter. Leather you CLEAN and prep. NO SANDING UNLESS YOU WANT TO HAVE A SCUFFED UP LEATHER PIECE instead of having a shiny finish. YOu probably could use that stuff from JC Whitney but if you dont clean it enough it will probably peel eventually.
Old Jan 12, 2008 | 08:24 AM
blue68f100's Avatar
blue68f100
If its leather dye is best. There are 2 different bases, one oil, the other alcohol based. The alcohol base is the one you want. It cleans up easier than the oil base. The oil base if not smooth yo will never get the chalking out. Chalking is a dry residue left behind when the leather drys. Both can penetrate the leather deeply, with the oil base having the deeper penetration. I have been doing leather craft for 30+ yrs. When you sand leather it will end up as a suede finish and will not look natural. There is some special cleaner to use that does not require you to sand on it. Now I have seen leather that was only surfaced dyed, and thin (1/32"). And the good stuff is processed so its color is all the way through and 1/16" think.
Proceed with caution or you will ruin it.
Old Jan 12, 2008 | 12:19 PM
gustav129's Avatar
gustav129
If it's vinyl, the spray can paint (which you can get at NAPA) works great. I used black in my Scout II years ago to cover the puke green and it hasn't faded or peeled yet. Seats, dash, center console.
