94 Explorer AC/Heat Blower Intermitent On-Off
Old Aug 21, 2007 | 09:16 PM
bfc4's Avatar
bfc4
Question 94 Explorer AC/Heat Blower Intermitent On-Off
The ac/hear blower occassionally goes off regardless of setting and regardless if running ac or heat. I'm thinking it is related to the blower relay but not really sure. It can run for hours without an issue or can come on and off every 5-10 minutes. I think I'm going to swap the relay since it doesn't cost too much.
Has anybody else had this issue with their '94 Exploder Limited?
Old Aug 22, 2007 | 02:37 PM
marragtop's Avatar
marragtop
Make sure you have good connections at the blower motor. Don't forget the ground.
Old Aug 22, 2007 | 05:22 PM
steve(ill)'s Avatar
steve(ill)
when it stops, move the multi speed **** to see if any speed works. if not, you are on the right track, it is the power feed, or the wire to te blower motor (or ground). if one speed does work and another does not, you could have a bad resistor terminal on the resistor block.
Old Sep 3, 2007 | 03:23 PM
bfc4's Avatar
bfc4
Relay Fixed Blower
Well, it looks like the relay was the issue. I guess after 170k miles, it was due.
It was a cheap fix too. Went by NAPA, put it in there, and all done.
kkyy96
2009 - 2014 F150
Apr 1, 2013 01:31 PM
Doug3524
Jul 18, 2012 09:55 PM
sp21
1997 - 2003 F150
Aug 20, 2010 11:00 PM
New2Trucks
Mar 9, 2009 06:25 PM
cantman
Apr 29, 2003 05:13 AM
