Need help on My 89 Ranger
Old May 30, 2007 | 07:57 PM
kid88's Avatar
kid88
Angry Need help on My 89 Ranger
My 89 ranger won't start. I drove it to the gas station and when i tried to start my truck, it didn't want to start. So, i try to jump it and it didn't work. I then replace it with a new battery and it still won't start. I checked the fuse and the fuse was ok. Everytime i tried to start it the noise that comes out was a knocking sound. I have full power , radio and headlights still works. I don't know whatelse to check for. Please help.........
Old May 30, 2007 | 08:41 PM
fflintstone's Avatar
fflintstone
Welcome to FTE Kid88. If you could describe the symptoms a little more fully, it would be easier to guess what might be up. Does it turn over at all? Can you hear the fuel pump run for a second or two when you first turn the key but before you turn it all the way to engage the starter? Hang in there my freind, somebody with the know on those old 89's will be by soon enough.
You may have blown a relay to either the fuel pump or the PCM. That is just a guess.
Good luck
Fred
Old May 31, 2007 | 03:04 PM
cddz's Avatar
cddz
i wander if he means a ticking noise say from like a bad solenoid?, if it is turning over and making a knocking noise could be a craked dist cap
Old Jun 1, 2007 | 06:15 AM
kid88's Avatar
kid88
Cool
No, it doesn't even turn over. It is a rapid ticking noise. There was a loose hot wire that was touch the car frame. I thought the fuse might have been blown but apparently not.
Old Jun 1, 2007 | 07:39 AM
cddz's Avatar
cddz
the starter is toast, replace it and your truck will start.
