1960 F-600 Sector
Old Dec 23, 2006 | 04:40 PM
Tater50's Avatar
Tater50
1960 F-600 Sector
Steering sector has about 3 1/2" of play; bolt w/locknut has been adjusted in to the max; anyone know of a parts supply that carries these? Can these be sent to a machine shop to be remade?
Thanks
Tater
Old Dec 23, 2006 | 10:17 PM
56f600's Avatar
56f600
Boy I don't know. When mine gave it up I replaced with a box out of a '59 F500 that was sitting in a local wrecking yard. I wish you luck.
Old Dec 23, 2006 | 11:07 PM
Tater50's Avatar
Tater50
OK will look around
Thanks Mark: I will see if I can find one, very rare.
Tater
Old Dec 24, 2006 | 12:19 PM
HT32BSX115's Avatar
HT32BSX115
That steering box was the same for many years. Have you checked with Ford? Also Joblot may have parts for a model that will fit.
Regards,
Rick
Old Dec 24, 2006 | 12:43 PM
idaho211's Avatar
idaho211
It looks like it had different steering boxes for F-600:
59/60 F500/600
4M, 4.7 M front axle utilizes B7Y-3575A sector shaft and a 1 ton 59/60 3.8 gemmer steering used the same sector. So you could find a 59/60 1 ton with 3.8 gemmer steering it uses the exact same box and shaft.
If it is a F-600 that uses a
6M front axle B7Q 3575-A sector shaft
I bought a new old stock shaft for my truck 60 4x4 from Dennis Carpenter. I e-mailed them and they got back with me within a few days.
I looked in my JoBlot catalog and they list a new old stock sector shaft for B7Y-3575A for $295.00, spendy but NOS. (718) 468-8585. I bought from them and have not been disappointed.
Good luck
Old Dec 24, 2006 | 02:21 PM
Tater50's Avatar
Tater50
Good info
thanks for the replies, will check
Old Dec 24, 2006 | 02:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Here is another possibility...If you can find just a matching roller, you can press off the old one and press on the new.
Edit: see post below
Old Dec 24, 2006 | 02:51 PM
NumberDummy
Sectors
1959/60 F600
B7Y-3575-A sector, steering shaft
Front Axle: 4M, 4, 7M;
Housing number: 4CC25
Complete Assy: B7Y-3504-A
OR
B7Q-3575-A sector, steering shaft
Front Axle: 6M;
Housing number: 5DC25
Complete Assy: B9T-3504-B
Note: 1959 & 1960 F350's w/3.8 Gemmer use the same steering box as the first F600 sector (B7Y-3575-A) I listed above
tater_51
Jul 18, 2014 12:03 PM
mgerdau
Aug 27, 2013 06:52 PM
Tater50
Dec 20, 2010 03:00 PM
RustyTrustyF150
Oct 28, 2010 01:51 PM
Tater50
Computer Chips & Tuners
Dec 24, 2006 02:11 PM
