I was debating on posting this in the Superduty section, but thought better about it. I'd like to get the opinion of the V10 guys. I have a 02 F350 with 4 inches of lift. I'm runnin 315/70/17 BFG's. (Basicly 35" tires) The 3.73 gears in my truck make's it feel like a slug, So i think i'm gonna bite the bullet and get some new gears but i'm so undecided on the ratio. I've read a bunch of posts and now i'm even more confused. (Yes I know how they work and why, I'm just scared of dropping a bunch of money and not being happy with it.) I was thinking of going to the 4.30 gears, then again why not the 4.56? Or even the 4.88's... I was thinking of getting some 37'' tires when these ones wear out. So I need some input! And does anyone know a good online site for gears? I'm more than capable of installing them myself. I tried a parts store up here in canada and they wanted 500 for the gears and a mini install kit. I thought that was kinda pricey!
Ken is dead-on. Go w/ the 4.88's. You'll be happier in the long run. Heck, I've got 4.30's now w/ 285's and I'm thinkin about 4.88's. If I was running 37's, I'd probably look into 5.14's or 5.38's. Good luck.
I went from 4.30's to 5.13's after I bought a 34' toyhauler.I already had 38" tires,so I needed the 5.13's to get me in the torque sweet spot when towing.Especially pulling big grades.Hauls @ss without the trailer hooked up!
I know I'm not gonna get great mileage out of a V10.Especially w/38's or pulling a trailer.I just gas up when needed,who cares We didn't buy these trucks for mpg,we bought them for power without the cost and upkeep of a diesel....Right guys
Fredvon4-
I imagine that I get around 9-11 mpg unhooked and 7-9 hooked up.I never got the speedo/odometer re-calibrated for the 38's so I can just estimate.
I helped a guy back a few years with a botched Fabtech 8" and traxus Mudders in the 38 x 16.5 range
On my recommendation he had 5:12s, air lockers, custom full articulating drive shafts, long (I mean real long) torque bars on the rear axle, basically a 4 link system designed by me, I did the install and tune for the Nos system. Frank has a lot of money and had a hard head with a very hot PSD to respond to.
During the testing, we ultimately broke the 4R100 and the transfer case.. but I have to say, before we broke it, the 4R100 (I drove it several times) behaved and shifted normally in spite of the added torque load... remember the lower gears and the higher diameter tires makes the engine RPM to speed (MPH) ratio about the same as stock... only real difference is the feedback torque load
This truck is the 01 I had the most experience with. Most of the mods are similar to what you went through with the 05 except the programers of the day were not as sophisticated as the one you got to play with.
It was a 2 door 01 F250 LB 4x4 ESOF. He ran it several times at Little River 1/8th and was busting into the 12s (corrected 1/4 mile) fairly consistently. For the drag races I convinced him to slap on Dick Cepec 32x13.5s and run 4x4High
I also helped with a very high lifted Excursion that was PSD into a 4R100 and it too (once bulletproofed by Brian) behaved surprisingly well for street driving.
I think dmilkman probably does not having any shift problems.... but I hope, if his 4R100 is stock, that he considers one of the re-builders out there that can "bulletproof" it. There are several areas with Ford original parts inside that are light weight crap and not very durable for high torque application
yikes. i'll bet that auto trans dosn't shift correctly.
It shifts perfectly,no complaints.I've been driving/towing with it that way since 2002.I also installed a second larger tranny cooler in line in front of the radiator to help the stock tranny live as long as possible.
