Blown V10 with only 13K miles!!!
We only drive this motorhome about 2-3K per year, so I'm out of Ford warranty because of 5-year age. The Extended Warranty company is waiting to hear about the diagnosis before they will commit to paying anything.
What in the world could have happened to this engine???
Interested in any thoughts. Thanks!
sounds like dealer 2 has a scope called a bore scope which allows a tech to look though a fiber optic in though the spark plug hole to see and photo the problem inside the cylinder.
this dealer is well set with tools of todays needs that help save time .a bore scope is not cheap but man does it help big time.
as to jumping time i sure would like to know what they find as this motor has a set of 2 timing chains to turn the camshafts."one for each bank" please let us know what they find that was the cause. ie. loose camshaft gear bolt? bad keyway? as you state 13k something came loose or broke in my mind. again please tell us the final result
I had a valve bent in my v 10 (01 Gulfstream motor home) it had 14,172 miles when I pulled into the Ford garage. I now have 17,000 on it but I had a rebuilt engine put in.
The trouble started when a spring keeper fell off for #5. ( a guess)
I am not sure when it happened ,but I had no trouble climbing hills other than a vibration in the steering wheel. I thought it was the drive shaft.That is what I brought it in for.
BTW, My '05 SD spun a front main crankshaft bearing and totally lost all oil pressure and self destructed at 5000 miles. No one ever found out how or why (at least they never told me), but I got a brand new motor from Ford, and now with 15,000 miles it runs fine, so $%*t happens at that motor plant.
the way this cam drive is set up BOTH drive gears on both heads would have to fail the keyed and bolted position on the front of the cam....
I doubt the crank drive gear can shift position and the way the idlers are set up, there is no way a chain can jump a tooth...
So I wonder is it is possiblke that all 20 Valve spring keepres fail simultaniously...man that would be real weird but is only thing I can think of to cause all exhaust valves to hit pistons except a sudden shift of cam position and then the intakes would have to take a hit too...
I am dying to know more about this... it will be the third V10 I have heard about with a sudden death at 12-16 thousand miles
psweath
When they get done with the autopsy... try and post pictures if you can
A mechanic who took the timing chains off for some ungodly reason, and re-timed it VERY retarded. Piston coming up on exhaust stroke, hits exhaust valve while it's still open. Repeat 10 times. It wouldn't catch the intake valve, because those close when the piston is coming up after BDC, and if they are late, it's gotta be REALLY late to hit the intakes.
Is the timing chain on the crank a one-piece with two sets of teeth, one for each cam chain? Breaking that keyway (or lack thereof) is about the only way that could happen.
Here's the process from my '01 service manual for the F-superduty:
o Insufficient power
Possible Source(s):
§ Malfunctioning or damaged ignition system.
Action(s) to take:
§ Refer to the appropriate section in Group «303» for the procedure. REFER to the Powertrain Control/Emissions Diagnosis Manual («OBDII», «ODBII-Diesel», «ODBII-Bi-Fuel LPG/CNG»).
Possible Source(s):
§ Malfunctioning or damaged fuel system.
Action(s) to take:
Possible Source(s):
§ Malfunctioning or damaged air intake system.
Action(s) to take:
Possible Source(s):
§ Damaged or plugged exhaust system.
Action(s) to take:
§ INSPECT exhaust system.
Possible Source(s):
§ Incorrect tire size.
Action(s) to take:
§ REFER to «Section 204-04».
Possible Source(s):
§ Dragging brakes.
Action(s) to take:
§ REFER to «Section 206-00».
Possible Source(s):
§ Slipping transmission.
Action(s) to take:
§ Refer to the appropriate section in Group «307» for the procedure.
Possible Source(s):
§ Malfunctioning valve tappet or lash adjuster.
Action(s) to take:
§ INSTALL a new valve tappet or lash adjuster.
Possible Source(s):
§ Damaged valve tappet guide or valve tappet.
Action(s) to take:
§ INSTALL a new valve tappet guide or valve tappet.
Possible Source(s):
§ Compression leakage at valve seat.
Action(s) to take:
§ REPAIR or INSTALL a new valve, valve seat or cylinder head (6049).
Possible Source(s):
§ Seized valve stem.
Action(s) to take:
§ INSTALL a new valve.
Possible Source(s):
§ Weak or broken valve spring.
Action(s) to take:
§ INSTALL a new valve spring.
Possible Source(s):
§ Worn or damaged cam.
Action(s) to take:
§ INSTALL a new camshaft.
Possible Source(s):
§ Damaged head gasket (6051).
Action(s) to take:
§ INSTALL a new head gasket.
Possible Source(s):
§ Cracked or distorted cylinder head.
Action(s) to take:
§ INSTALL a new cylinder head.
Possible Source(s):
§ Damaged, worn or sticking piston ring(s).
Action(s) to take:
§ REPAIR or INSTALL a new piston ring(s).
Possible Source(s):
§ Worn or damaged piston.
Action(s) to take:
§ INSTALL a new piston and piston pin.
OTOH
I was going down the back side of a tall steep one in my 01 4R100 and the torque converter would not let me over tach the motor...almost cooked the brakes for lack of any compression braking...
Every time going down the back side in the 05 with the 5R110w the tow haul , locked torque converter, and down shift assisting the brakes for the descent there was no danger of over tach because I had full control...
I think all the motor coaches are all auto trans so probably the 4R100.
I guess it could happen..... but some how unlikely now that I think on it some
If this was a manual trany your therory would be sound thought
krewat suggested a mechanic who may have had the timing chains off, but this motorhome has only ever had routine oil change type maintenance. Dealer 1 is the only one who ever did more than an oil change. After they worked on it, it did seem to run worse, but I didn't really think they caused it, I just thought the condition itself was worsening. I thought for sure Dealer 2 said they had to drop the engine to get to the chains, and certainly no one has ever dropped the engine.
P51D Mustang talked about mountainous driving, heating up, then overrevving on the downhill. Actually it was when cresting a fairly steep hill (go from about 5,000' to 7,000') that the Engine light came on, and it was after that that things really worsened, like not starting. I do take it out of overdrive when descending hills, but can't think of any possible overrev condition.
The only other thing that happened with this unit was in the winter, which was the last trip prior to me initially noticing that slight surge at idle. I got stuck in the snow, and as part of getting unstuck, there was a lot of wheel spinning - in fact a slight burning smell at one point. But I got unstuck and drove another thousand miles and didn't notice any issue.
Stay tuned...
They probably have to drop motor because of motor coach design other wise getting to the front end in a normal truck is fairly easy just getting shrouds and radiators out of the way
You have to take any pictures once opened up..... they most like will not..... even if you ask
The broken motor is yours unless they have to trade it in as core for the rebuilt motor they are most likely going to swap in
Not reading properly your first post and the crank position sensor change by the first dealer I assumed the easy to get to CAM Position Sensor on front of pass cylinder head... but now that I re read the original post and think on it some.... a CRANK position sensor requires getting into the front of the motor behind all the FEAD (front engine accessory drive) stuff, and in doing that, the stupid technician probably did screw up the timing and your motor has been toast ever since that screw up...ever since they started it and gave up
Sorry brother but I will dispute with anybody how this damage can occur during normal driving even with a over rev if it was possible and with an unlocked torque converter in a 4R100 it is not likely to be over rev related
I got a bad feeling you are going to get screwed because there is no way to effectivly prove the first dealer did this I hope the folks who have it now can do right by you with a warranty repair motor
