Trip report: San Diego to Ohio and back towing
I towed my racecar in a 24' Haulmark to Mid Ohio Sports Car Course for the first NASA Championships and spent four days there. Car and trailer-7k weight plus tools, parts, etc. Estimated at 8500 going and 9500 coming back with spare parts I picked up for a fellow racer in Ill.
Speed 65 mph with cruise control there and back except when traffic or weather made me slow down.
Cal to Ohio netted 9.5 mpg, 2400 miles
Ohio to Ca netted 8.9 mpg, 2450 miles
One note on the return trip is that I bucked 40-60 mph head winds (with gust to 70) from Amarillo to Flagstaff (600 miles). The truck would not stay in 5th and stayed in 4th or 3rd depending if I was also going up a hill due to the head winds. That really killed my return mileage but not as much as I thought it would while also carrying the extra weight.
Zero problems with the truck, racecar or trailer.
Pulled off a 10th place finish out of 24 cars for the national championship.
Some say not to use CC while towing but the towing guide that came with the truck says that if the speed drops something like 8 mph or gains the same while towing, it will kick off and you will have to manually take over the throttle. Basically, nothing says not to use CC and the mileage seems to be really good with it so I will continue to use it while towing. If you think about it, it's no different than me keeping my foot in it to keep the speed the same going up hills than the computer doing the same thing.
Kevin, 05 250 SD, V10, 4x2, 4.10, CC, Torqueshift towing the #63 CMC Mustang
Rob
YES, use that CC...and let the SD take it from there.
Congrats on the 10th place finish!
biz
Great report, Congrats on the 10th place those courses are tough, much fun to watch... I missed it on Speed channel ...hope they re-run so I can try and pick out you and your car
REF the cruise control
Your 2005 is electronic throttle and the Cruise Control is integrated int that system. No longer an additional vacuum or mechanical actuator and all the extra sensors... That "smart" Cruise Control coupled with the "smart" Transmission (5R110W) makes for a very efficient and competent combination.... Mine will adjust speeds in 0.25 MPH increments according to my high tech GPS....smoothest operating CC I have ever owned. I use it every day and on every cross country trip in normal or Tow/Haul mode and it is about as perfect a system as I think can be designed
Can you tell I like the refinements in the 05 and up 3v V10 and 5R110w power train? BSEG fer sure!
