96 Ford Explorer-Fuel Problem
Old Aug 1, 2006 | 01:44 PM
brittg2cat's Avatar
brittg2cat
Occasionally it will not start, acts like it's either flooded or no gas? Took to shop and they ran a test on fuel line says pressure for fuel pump should be around 35-40 and the reading was 32 does this mean I need to replace the fuel pump? Not an expert on vehicles so I need everyone's advice before PAYING for repair.
Maybe the fuel filter needs replaced? Or the pump? Any suggestions?
Old Aug 1, 2006 | 06:05 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 1, 2006 | 09:19 PM
Ford_Six's Avatar
Ford_Six
Welcome to FTE!
I would try a new fuel filter first, then go from there.
Old Aug 4, 2006 | 07:41 PM
subford's Avatar
subford
Not true, the fuel pressure should be between 30-45 psi. If it was idling with good vacuum when the they got the 32 psi then that is a normal reading. The 45 psi is with no vacuum.
