> Engine ticking on 4.0L, have a few questions before I start.
He's got a little ticking that he wants to get fixed.
I just found this thread here:
https://www.ford-trucks.com/forums/s...9&page=1&pp=15
But this is what I was originally thinking:
First thing that comes to mind that's probably easiest is an exhaust leak. Is there any way to tell for sure it's the exhaust/header, short of pulling it apart and putting it back togother?
Next I would check the injectors. Unplug the power to each one, one at a time, see if the ticking goes away. If it DOES, I've narrowed it down to either that injector, or valvetrain of that cylinder. If it DOESN'T, then I move to the next step, and pull plug wires one at a time.
Now, with the injectors all plugged backin, next I would pull that plug wire. If the ticking STAYS, then I know it's the injector doing the ticking. If the noise goes away, then more than likely the problem is in the lifter/rocker arm.
Sound about accurate? I suppose I could do it backwards, pull the plug wires, but if it's a bad injector, the noise won't go away by pulling the wires, so I'd probably be better off checking the injectors first.
Are these things a roller or flat-tappet cam?
I don't think a rocker arm would tick, since they're probably just stamped steel...
Thoughts? Thanks.
How much will this cost in parts so I can let him know?
What's a fair price to charge him for this job, assuming it's this timing tensioner crap? I will try to eliminate the easy stuff first of course.
Thanks!
No idea in parts 'til you diagnose the problem.
The timing tensioner is fairly reliable from what I hear. I wouldn't be overly concerned with it. You seem to have enough mechanical know-how, and a good plan, to diagnose this problem.
Report back with your results and we can go from there. But your test seems quite sufficient in itself to begin with.
A little trick for diagnosing an exhaust leak or pinpointing the ticking. Get the longest screwdriver you have, put the tip on various places on the engine, and listen to the other end. You can do it on the exhaust, the valve covers, wherever necessary. It makes it easy to track down a noise for sure.
RP
Zach
If it's the SOHC version, then you're probably hearing the onset of the timing chain tensioner problem.
FWIW, I thought the '00 Rangers still had the OHV version (an OHV-equipped vehicle will have an "X" as the 8th digit of the VIN).
It doesn't look too easy to reach the injectors, but, I might be able to yank some stuff off the engine to unhook them. Very lucky for me it's OHV...I could work on the OHC, but, I'm a lot more knowledgeable in simple pushrod operations. I'll try to work the injectors, pull out my mech stethescope, and start probing around tomorrow then...
You wouldn't happen to have a link to that valvetrain refresh kit would you?
http://www.deltacam.com/index.php
If it's the OHV, then THIS ARTICLE should help you with some of the upper engine removal process.
Nevermind...I see it now...shaft rockers, sweet!
Thanks for the article!
Lifters
Pushrods
Valve Cover gaskets
Upper Intake gaskets
Lower Intake gaksets
3 x O-Rings
