2" body lift.
Old Jun 28, 2006 | 10:19 PM
willie4406's Avatar
willie4406
Exclamation 2" body lift.
hey i just bought some bigger rims and tires for my '91 Ranger and i know that they will not fit in my front wheel wells. so i'm going to put in a 2" body lift... the only problem is.. I don't know how! heh so i was curious to see if someone could let me know how to do this... tire size i bought are 235/75r15. thanks!
Old Jun 29, 2006 | 06:02 AM
Alan D.'s Avatar
Alan D.
Get a spacer kit, probably off ebay. this will cost between 50-150? not sure though. did it to a dodge. then you take the front suspension apart. shock tower comes off. put spacer in, shocktower in, and spring. reasemble. it's not to hard, just need a spring compresser tool thingy to get spring back in place. no noticable difference in ride, well a little smother from larger tire. but this is referanced off a dodge. dont know if it works the same on a ford. it should though. the ford might need a longer shocks. other than that, it takes around 30 mins for each side. easy fix... i think.
