'00 still have problem with turn signals
Old Jun 17, 2006 | 02:06 PM
96brco's Avatar
96brco
Turn signals started working intermitently a few weeks ago. Now they're not working at all. After checking fuses, relays, bulbs, etc, and reading some posts about similar problems, I replaced the multi function switch and one of the the grey wiring clips that had some tabs broken off. After all that, I've still got the same problem. The hazards work fine, as do the other systems controlled by the MFS. I also changed the rear bulbs for laughs. No change. I need help! Any ideas?
Old Jun 18, 2006 | 12:33 PM
87 XLT's Avatar
87 XLT
Take a look at your wiring diagram, odds are theres 2 fuses wired to a single flasher.
One side of flasher is wired to the hazards, other side wired to turn sigs. This is "probably" how it's wired.
Sounds like bad flasher or a break in the wire in the column.
Old Jun 19, 2006 | 03:29 PM
96brco's Avatar
96brco
Thanks. I'll take a look at the wiring again and try to figure that out. So far, all the fuses I've checked are okay though.
Old Jun 20, 2006 | 05:46 PM
JoeyBagodonuts's Avatar
JoeyBagodonuts
i had the same problem before but it was because i changed my dashboard display..i installed a white faced gauge...for some reason if my steering tilt was all the way down, it wouldnt work....if i moved it up a little it would be fine.....not to sure if it will work but worth a try.....
Old Jun 26, 2006 | 09:41 AM
96brco's Avatar
96brco
Turns out it was the turn signal relay.
