queston about fuel injectors.....again!
Old Jan 7, 2006 | 06:11 PM
mechanicgurl's Avatar
mechanicgurl
Exclamation queston about fuel injectors.....again!
Hey guys, another question. Can I swap fuel injectors from a 5.0 engine into a 5.8 engine?
I need an answer pretty quick. Any help always appreciated.
Thanks
Old Jan 7, 2006 | 07:50 PM
LxMan1's Avatar
LxMan1
You can get buy with using the yellow top 19lb injectors in the 5.8L. These would be in either a Mustang or a Lincoln Mark VIII with the 5.0HO. Standard 5.0's use white top 14lb injectors. Those might not feed the 351 properly.
Old Jan 8, 2006 | 07:26 AM
EPNCSU2006's Avatar
EPNCSU2006
5.0 trucks used 19lb injectors, same as the 5.8...
Old Jan 8, 2006 | 09:01 AM
mechanicgurl
Okay, so what you're both saying is that I need to make sure that they are the 19lb. ones, and not the 14's? We'll have to double check, I think the fuel injectors have come out of a 5.0 truck.
Thanks
Old Jan 8, 2006 | 12:13 PM
mechanicgurl
Unhappy
Okay, went ahead and checked. The one's coming out of my 250 are the yellow (19lb) topped ones. The one's that came out of the other truck are white (14lb). Busted my bubble. Thought I might have something to work with. Any suggestions on where I can find a set fairly cheap. Money is a major issue at this point. That's why we were looking to swap them.
Thanks
Old Jan 8, 2006 | 12:28 PM
LxMan1's Avatar
LxMan1
Local junk yard perhaps?
Old Jan 8, 2006 | 12:38 PM
mechanicgurl
Went that route...the two junkyards I did fine who had the injectors wanted as much as the part store did. I'm checking ebay now, and some other online stores, see what I can dig up. Thanks for the help!
Old Jan 8, 2006 | 12:47 PM
LxMan1's Avatar
LxMan1
Why do you need new injectors. What kind of problems are you having?
Old Jan 9, 2006 | 06:04 AM
mechanicgurl
Started running rough, then came to the point it wouldn't even start. Took it all apart, new fuel pumps, the whole works, checked to make sure that there was power going to the injectors, no problem there, the fuel injectors are majorly gunked up and nasty.
Old Jan 9, 2006 | 10:51 PM
LxMan1's Avatar
LxMan1
OK, Did you check for injector pulse with a noid light? They are about $10 at AutoZone.
You might try the white top units to verify that it is actually the injectors causing the problem. It will run, but may be lean under heavy throttle.
Old Jan 9, 2006 | 11:08 PM
Chevy_impala57's Avatar
Chevy_impala57
Some body put sugar in my friends 5.0 mustang a while ago. So i went to the junk yard (they were grey tops) got some out of a crown vic. In the end due to damage in the ended up that i had 4 crown vic and 4 mustang. Put them in Ran like it had a huge cam. So i went back to the junk yard looking for orange tops, All the trucks had them eccept 87 86 85. The newer 5.0 and 5.8 had the same numbers stamp on them used them. Ran better that before
Moral of the story just make sure the numbers the same and u wont have a problem
Old Jan 10, 2006 | 06:38 AM
EPNCSU2006's Avatar
EPNCSU2006
My 87 came stock with the orange top injectors
Old Jan 14, 2006 | 12:29 AM
Chevy_impala57
Wink
well i never once clamed to be a ford efi Expert just explaining what i seen
Old Jan 18, 2006 | 05:11 PM
jamespud's Avatar
jamespud
I had my injectors cleaned at a local machine shop, cost me $12 each (included new pintle caps, screens, and spacers) and now they work perfect. You might check around and see if your local machine shop can do this for you.
Jim
BuickBrian
WTB - Parts & other
Feb 2, 2017 10:15 AM
MONAVIERONJON
Dec 24, 2016 09:44 AM
Renneberg
Aug 3, 2014 10:47 AM
RobbyMartin
1997 - 2003 F150
Feb 14, 2010 08:42 PM
Jimn8or
Dec 10, 2008 11:47 PM
