Use Diesel water trap to strain gasoline?
Old Oct 26, 2005 | 06:07 AM
four-sixty-power's Avatar
four-sixty-power
Lightbulb Use Diesel water trap to strain gasoline?
All diesels use a water trap to seperate water from the fuel, right?
Why couldn't I use a water trap on a gasoline vehicle, and then fill up at all those "shady" gas-stations, that some of us think have water in the fuel?(including me)
Old Oct 26, 2005 | 06:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
They make water absorption filters for hydraulic oils etc also. Check at the farm supply stores and hydraulic equipment supply houses?
Old Oct 26, 2005 | 06:54 AM
spacecoast's Avatar
spacecoast
My 53 F100 has the OE gas filler - if filling in the rain or forgetting to put the gas cap on could allow water to enter the tank - A marine fuel filter from a I/O automotive style engine will get the water before it gets you - my instalation is on the firewall near the frame rail
Old Oct 26, 2005 | 09:01 AM
four-sixty-power
I was thinking of something with a trap or a drain valve so I can see how much water per tank came from which gas station when I drain the water. I'll have to look around and see what I can find...
Old Oct 26, 2005 | 09:36 PM
Ford_Six's Avatar
Ford_Six
I don't see any reason why you couldn't run a water seperator on a gas vehicle, as long as it was carbureted. If it's EFI, you'll have to check the pressure rating of the filter to make sure it can handle it.
redz284u
Feb 24, 2017 09:42 AM
jaynik123
6.4L Power Stroke Diesel
Jul 1, 2016 03:48 PM
littleapple
6.7L Power Stroke Diesel
Nov 10, 2015 09:12 AM
jzedaker
1983 - 2012 Ranger & B-Series
Oct 23, 2015 01:00 AM
fitz888
2004 - 2008 F150
Nov 22, 2008 08:02 AM
