truck avenger power valve
Old Oct 17, 2005 | 06:18 PM
bonechief's Avatar
bonechief
I have a new Holley truck avenger. It has the new anti blow back power valve in the carb. I had a bad back fire the other day and now i have a miss, what are the symptoms of a bad power valve.....There are no vacumm leaks that i can find and it just had tune up less than 3000 miles ago..Any idea's anyone.
Old Oct 17, 2005 | 07:12 PM
fmc400's Avatar
fmc400
MSEE
A blown power valve will cause an extremely rich condition. You'll have a rough idle and possibly black smoke in the exhuast. I'd start diagnosing the miss with a compression test.
Old Oct 17, 2005 | 07:46 PM
fastback69's Avatar
fastback69
A quick way to check for a blown power valve is to turn one of the idle mixture screws in. If the engine stumbles and tries to die, it's probably ok. If the engine doesn't change, it's probably blown. I've blown a few power valves with the "protection kit" installed.
Actually, this is a good test for any internal fuel leak. I have also seen cut O-rings on the accelerator pump transfer tube, and gaskets that don't seal the metering block to the main body also cause internal leaks.
TheSterling
Mar 19, 2016 08:27 PM
65fordguy
Jul 5, 2015 04:33 AM
rdweathers
15
Mar 23, 2013 09:56 AM
avenge
Apr 21, 2011 01:48 PM
176ford
Mar 30, 2004 10:40 PM
