Rebuilding 3 on tree
Old Sep 14, 2005 | 02:49 PM
Broomfieldbum's Avatar
Broomfieldbum
Talking Rebuilding 3 on tree
I was wondering if anyone has reebuilt their 3 speed on the column linkage, and if it is a matter of bushings, and such or will I most likely have to recreate much of the linkage??
Broomfieldbum
Old Sep 14, 2005 | 03:16 PM
fking1's Avatar
fking1
Rebuilt my 55's 3 speed. About the only thing available are bushings and brass washers for the bottom links. Where the rods go int the trans levers did nothing as it would require welding and re-drilling the holes to eliminate the slop. My shift lever/linkage has alot of play, but, I will live with it.
Fred
Old Sep 14, 2005 | 04:13 PM
Scott123's Avatar
Scott123
Just rebuilt mine on my 51 a few weeks ago. Put the new bushings in the levers. Be sure when you order the new bushings that they supply the tool to install them too. The levers were in excellent shape for being so old. I replaced the rubber insulator where the shifter lever attaches to the top of the column, and found a new spring at Ace Hardware to replace the one in the top of the shift tube. Also replaced the bushings on the shift rods that connect to the tranny, which was rebuilt with all new parts. There's still a little bit of slop, but it's as close to factory condition as it could get. Just replacing the bushings on the ends of the levers and the shift rods can eliminate a lot of play if yours are shot.
Scott
Old Sep 14, 2005 | 04:18 PM
Scott123's Avatar
Scott123
One other thing I forgot to mention--if your tranny leaks any out the side plate, where it can dribble down the shift arms onto the rubber bushings on the shift rods...my last set of bushings dissolved in a fairly short time after they got soaked with transmission grease. I had to search to find a side plate that didn't have the arms welded on, but when I got one, I replaced the seals in there too.
Scott
Old Sep 14, 2005 | 04:33 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Where did you find the seals? One of mine is a bit worn but I put it back in since I couldn't find a source for it.
Kevin
1953 Ford F-100
Go Illini
Old Sep 14, 2005 | 07:25 PM
Earl's Avatar
Earl
I'm pretty sure I got mine from JobLot Automotive and the seals were included in the gasket set.
Old Sep 15, 2005 | 10:36 AM
Scott123's Avatar
Scott123
I got mine from Classic Auto Parts in Oklahoma City, used to be Obsolete Ford. They were cheap, only a dollar or so each.
Scott
