04 EXPY EB Siruis Kit
Old Sep 29, 2004 | 03:15 PM
phikappapsi1273's Avatar
phikappapsi1273
Has anybody installed the sirius kit for an 04 EB EXPY with the Audiophile 6 disk changer. The dealership wanted 350 for the kit and 200 to install it. I think that is a little steep. any help would be appreciated.
Old Sep 29, 2004 | 06:35 PM
dlafleur's Avatar
dlafleur
I installed on in mine. All I can recall was that the tab was over $400. Definitely worth it though. The installation was first class, that is invisible.
Old Sep 30, 2004 | 07:27 AM
propellerhead's Avatar
propellerhead
I want to do the same in a Mustang. It has the "SAT" ready 6 in dash CD changer. The dealer quoted me $399. Or, I can buy the same kit the dealer would install for $250.
http://www.radiosandmore.com/prod_detail.asp?pn=4047452
Old Sep 30, 2004 | 08:11 PM
expyfan's Avatar
expyfan
I had it installed in June in my 04. Price was $399. Loving every moment with it. Dealer did a great job concealing the install as well. Yes, I do have the 6 disc changer. Item of note - you will get much deeper base due to the low bandwidth sirius is transmitting
Old Nov 24, 2004 | 04:25 PM
crazedhick3's Avatar
crazedhick3
Do you have to buy a kit from the dealer or can an aftermarket kit be installed on the factory head unit?
Old Nov 30, 2004 | 09:44 PM
hickey01's Avatar
hickey01
Any instruction on the sirius add on kit
I recently bought the OEM kit, thinking the instructions would be with it, no dice. Need help on the install. Just bought the 2004 EB Expedition and wanted to save the $600 the dealer quoted me for the install. Could be in trouble. Got it from radiosandmore.com for the $225. Any help would be great. Thanks.
Old Dec 1, 2004 | 08:22 PM
mbbutler30809's Avatar
mbbutler30809
Dealer Price for Sirius Install
WELL WORTH IT. I installed mine myself. Receiver mounts over left rear wheel next to subwoofer. Cables must be run up tp head unit in dash. Antenna must be mounted and cable run to Satellite receiver. 6 hours and busted nuckles. LET THE DEALER DO IT.
Old Dec 1, 2004 | 08:51 PM
hickey01's Avatar
hickey01
Really, that bad. I have read so many different views, but no details. Where can I find some details on the install? Are there any? I figure the dash comes off and the harness goes to the back under the carpet, etc.... I can't imagine this taking 6 hours. If this is the case - to hell with the self install.
Old Dec 4, 2004 | 12:13 AM
InstallzDotCom's Avatar
InstallzDotCom
Hey guys. I can install these kits in about 30 - 45 minutes. For the first timer I would say 2 - 3 hours without rushing is doable. Here's the basic install list for the 04 Expedition:
1. Remove (2) 7mm from the cluster area which secure the main trim bezel.
2. Carefully pop the trim bezel off and undo all the harnesses at the rear. This honestly is the worst part of the install. Be sure to tilt the wheel all the way down, apply the ebrake, and shift into the lowest gear (ignition on only, car NOT running!)
3. Once that panel is out of your way, remove (2) 7mm that secure the radio and remove the radio. Feel free to completely unplug the radio to make room.
4. Route your harness from under the steering column area up to behind the radio area. All the slack on this harness will be run to the rear of the vehicle.
5. The 2 connectors both plug in to one another there is no wiring involved with the kit. Plug in the appropriate plugs, and then reinstall the radio remembering to plug in all harnesses and the antenna.
6. Now to start running the harness to the rear. Pop off the drivers door sill first, then the drivers kick panel. Also pop off the drivers rear door sill panel. You will also want to pull off the rubber seals on both sides of the b-pillar, and pop the panel out slightly to run the harness behind in.
7. Run your harness down the driver side of the vehicle towards the rear. There is plenty of slack you can leave a little play on the harness in the underdash area if you'd like.
8. Open the rear hatch and pop out the tray and cupholder from the drivers side rear. Both just pop out there are no screws.
9. Route your harness up through that area and out of the hole for the rear tray.
10. Plug the harness into the main module module and the MUX module if you have the rear DVD kit.
11. Place the antenna centerered on the rear of the roof. The main antenna part is magnetic, and the stalk? part of it you need to apply the supplied double sided tape. There is also a alcohol pad to clean the roof surface of any debris before installing. Positioning the antenna is much easier with the rear hatch CLOSED so you can stand on the bumper.
12. Next open the rear hatch and start to run the antenna lead down. Be careful not to kink the lead which is very easy to do. Pull the rubber seal off around the top of the hatch area, and file a small groove in the metal lip that the rubber seal pops over. This is to run the antenna lead without crushing it. I prefer to bring the antenna lead in dead center straight down. Just leave slack on the lead so it lays in the area between the rubber seal and the roof itself, rather than being tight.
13. Route the antenna down to the module and plug it in. Be careful when routing the antenna past the seat belt so it doesn't get caught up when using the seatbelt.
14. Tie up all the extra slack and mount the module inside the rear side panels. I prefer to just use a piece of velcro rather than those metal brackets they give you. Replace all your panels and give it a try. You MAY want to test it before replacing all your panels if you don't have much faith in your work
15. Turn on the radio and hit the SAT button. You will only get the Sirius preview channel at this point.
Troublshooting
If you don't get the preview channel right away, don't panic this is normal. It sometimes takes about 10-15 minutes for me to get the preview channel to come in. In this time you may get no antenna errors, service sat errors, and just random things. If the radio display shows 1 khz, that's a good sign. Try cycling the ignition off, then back on and see what happens. Try turning the radio itself off and on, and see what happens. Try hitting the SAT button and just leave it sit for a few minutes, it usually pops on eventually. Lastly try hitting the seek and other buttons, and it will come on eventually.
If you have the OEM indash nav unit (this is common on navigators, not 100% sure of this being offered on the expeditions), you may need to have the software programming upgraded before the sirius will work.
Finally call the local car audio shops in your area to see who deals with ford/visteon. Like the "Ford" remote starters in most cases the dealer themselves doesn't install these systems they call in a third party and jack the price. I believe we charge the dealer somewhere around 350 - 400 installed for these systems, including all parts and labor, so if you guys are getting quotes of 600 you can see what's happening..
Anybody in the NEPA area who isn't up to installing these themselves, I am available for installation at a very reasonable rate. Any problems or questions feel free to contact me,
Mike
Old Dec 5, 2004 | 09:43 AM
rdrakea's Avatar
rdrakea
Question
"If you have the OEM indash nav unit (this is common on navigators, not 100% sure of this being offered on the expeditions), you may need to have the software programming upgraded before the sirius will work. "
So the Sirius add-on WILL work with the factory Visteon navigation unit? I called Visteon a few months ago and they said no.
Old Dec 5, 2004 | 12:33 PM
hickey01's Avatar
hickey01
Talking Very Easy Install
I would highly recommend doing the install yourself. Just finished mine in about an hour and the install is invisible and it works! Just follow Installzdotcom's instructions and you will listening in no time. Be careful with the dash though. Thanks for the help!
Old Dec 6, 2004 | 10:09 PM
Slurpeedread's Avatar
Slurpeedread
Hmmmm..... anyone know if this would be the same for a '05 Eddie Bauer??
If so... I know what Santa is bringing for Christmas....
Old Dec 7, 2004 | 05:50 AM
InstallzDotCom
"So the Sirius add-on WILL work with the factory Visteon navigation unit? I called Visteon a few months ago and they said no."
I replied to this yesterday, but it seems someone deleted my post for some reason? Anyway if you push and hold the audio and menu buttons on your radio it will bring up a keypad. Type in 917 and hit enter. Find the radio display part number and post it back here. I will check to see if that radio is on the list for you. I've done a dozen or more navigators with the indash nav, but honestly can't remember doing an expedition with the factory nav. Even if it is compatible, you will need to get your radio and nav software updated.
"Just follow Installzdotcom's instructions and you will listening in no time. Be careful with the dash though. Thanks for the help!"
Glad to hear you had good success with the instructions. I was typing it up from memory so hopefully I didn't leave anything major out. As mentioned removing the dash trim piece is the worst part of the install.
Mike
Old Dec 7, 2004 | 05:28 PM
rdrakea's Avatar
rdrakea
Ok...hold down audio and menu buttons? This is my radio. I think this is the same one in Navigators except it is silver in the Navs. There is no audio button.
Old Dec 9, 2004 | 11:54 AM
Matt03Expy's Avatar
Matt03Expy
Is there a OEM kit for an '03 Expy with the 6-cd (non-audiophile) system? Can I buy the '04 kit and will it work?
