Water leak from windshield seal
Old Apr 27, 2004 | 06:47 PM
nucleartruck's Avatar
nucleartruck
I have a water leak into truck cab. I notice a gap between windshield seal/moulding and cab (outside). I suspect this as the source. Anyone have the same problem? If so, how was it remedied.
Old Apr 27, 2004 | 08:51 PM
loveoldtrux's Avatar
loveoldtrux
Mine leaks the same way. I remedied it with bubble gum till I have time to replace the gasket...
Old Apr 28, 2004 | 06:38 AM
jkorreck's Avatar
jkorreck
My van leaks the same way, how do you replace the gasket on a windsheild? I can't actually see a hole, but water comes in at the top of the windsheild.
Old Apr 28, 2004 | 11:16 PM
95soontobelifted's Avatar
95soontobelifted
buy some good clear silicone sealant.
Old Apr 29, 2004 | 11:48 PM
dixon18's Avatar
dixon18
If we're talkin about a rubber mounted windshield, the cleanest way is to take the windshield out and put in a non-drying windshield sealant ( not urethane). The name eludes me but your local glass shop will know. Put around or just along the top of the rubber and reinstall the windshield. Have done this many times and it works well.
Chris
Alberta
Old May 26, 2004 | 10:58 PM
shrike's Avatar
shrike
It's called tremco, your glass shop will no what you are talking about, as stated above by dixon18, you don't want to use urethane sealer, that is for frame set windshields with trim moldings, and from a glass installers point of view, don't use silicone, it will seal the leak, however, it will also attract dirt and mold, and will show in about a week, not to mention the extra hassle that is needed for clean up if you have to remove the window at a later date. Hope this helps. later
Old Aug 5, 2004 | 08:49 PM
fbealer's Avatar
fbealer
you need bedding and glazing by adco silicone has an acid in it and will actually cause your truck to rust
Frank250Tank
May 27, 2016 04:11 PM
GeneGregory
Nov 3, 2015 02:43 PM
94 300
Jan 1, 2015 08:46 AM
78 & 87 Super Cab
Aug 2, 2013 10:08 PM
MikeB 88
1983 - 2012 Ranger & B-Series
Jun 16, 2008 07:17 PM
