ZF5 Synchro Replacement, Southern New Mexico
Old Jan 28, 2026 | 12:43 PM
1997.7.3.PSD's Avatar
1997.7.3.PSD
Anybody know where I can get the synchronizers replaced in southern New Mexico? I'm in the Dona Ana county area.
The synchros on 1, 3, and reverse are heavenly worn and 2 is completely worn. The shops I've asked either want to replace the transmission or can't do it.
Old Jan 28, 2026 | 01:10 PM
knottyrope's Avatar
knottyrope
Those are going to require a complete tear down of the main shaft that equals a complete rebuild. Did that my self before during covid to save a grand.
2500 for a rebuilt one plus shipping was more than my budget at the time.
Hope others chime in with a shop for you, only been there once like 26 years ago
Old Jan 28, 2026 | 06:24 PM
z31freakify's Avatar
z31freakify
Have you called Westside transmissions out here in Redd rd? I belive the vato does manuals if not he might know someone.
Old Jan 29, 2026 | 09:46 AM
Hit Man X's Avatar
Hit Man X
How is first worn? That gear is so low it may act worn but actually fine.
Anyway, DIY is best. I have the Rotunda kit you can bum from me
Old Jan 29, 2026 | 03:31 PM
1997.7.3.PSD
They're not able to do it.
Old Jan 29, 2026 | 03:33 PM
1997.7.3.PSD
No idea. That's how it was when I bought it. A shop replaced the clutch and told me the status of the synchros.
I might have to do it myself or pony up for a new one.
Old Jan 29, 2026 | 03:44 PM
Hit Man X's Avatar
Hit Man X
Start with the basics. Verify no air in the hydraulics. Fresh pedal box bushings and the guy on the swing arm.
Going into reverse is a pain. Clutch in, shift to fifth, keep clutch down, drop to neutral, keep clutch down, then drop into reverse. Works way easier. Even with crapped out dogs on the slider and gear.
I cannot see how first is worn unless trying to go from R to 1 over and over moving slowly. Possible, but not common.
Did the shop split the case and actually measure syncro ring clearance? My guess never have driven one and do not know how to shift them. TOTALLY different than small automobile manual boxes and does NOT shift fast.
Old Jan 30, 2026 | 07:11 AM
97-psd's Avatar
97-psd
agreed. They might be expecting to shift like a Miata, and it just won’t be like that. Pedal box bushing and hiem joint first then see how it does. It might also need a fluid change. If you go that route, it takes a Dex/Merc ATF. These things are getting several miles on them so rebuilds are more common but don’t jump to it until you get the basics sorted out.
what kind of clutch did they put in it?
Old Jan 30, 2026 | 08:09 AM
NM76F150's Avatar
NM76F150
I had a large improvement in my second gear synchro when I switched to Redline ATF.
Old Jan 30, 2026 | 08:39 AM
knottyrope's Avatar
knottyrope
Does the clutch engage low or mid pedal?
If low then the bushings and Heim joint can help.
If there is any drag on clutch when shifting, it wont be happy and feel like synchros are gone
Old Jan 30, 2026 | 04:15 PM
defdes's Avatar
defdes
Though my synchros are also bad (grinding sometimes into 3rd, 4th) for 10 years and difficulty in putting it in reverse, my clutch disengagement was about 1/4” off the floor, I replaced the master and slave and now have great pedal it will only grind slightly when down shifting into 3 & 4. I did the heim joint also a number of years ago.
Old Jan 30, 2026 | 05:24 PM
1997.7.3.PSD
The shop opened it up. The guy use to work for Ford back in the day. He also mentioned the 5th to reverse trick.
The truck had the heim joint mod when I bought it. It wasn't secured properly so the clutch wouldn't fully engage when shifting. I'm guessing this led to the synchros getting worn out.
Old Jan 30, 2026 | 05:27 PM
1997.7.3.PSD
I can't recall but it's equivalent to the stock one. They did change it to a single mass.
Old Jan 30, 2026 | 05:29 PM
1997.7.3.PSD
Mid pedal. The bushings and heim joint are good.
Old Jan 30, 2026 | 06:33 PM
TheFecalFanatic's Avatar
TheFecalFanatic
LOL @Hit Man X I was going to call you to this thread but you're already on top of it, you saint you.
