Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
2025 E-Series 450 Class C RV Dash Trim Removal
Old Aug 23, 2025 | 07:49 PM
twidget2000's Avatar
twidget2000
4th Gear
Is there any pointer to removing the dash trim on the 2025 E-450... I assume the 350 is the same... I am trying to replace the Manufacturer Radio (DOUBLE DIN) with a SIngle DIn unit and need to put a dash kit in... It will be easier if I can get the trim out of the way...
There were some wires I could not disconnect... and the vacum lines for the CLimate control are also an issue...
Thanks in advance ..
Old Aug 25, 2025 | 12:19 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Best way I know is to pull it off then pull whatever constraining controls etc. off of the back side of it.
Old Oct 26, 2025 | 03:54 PM
e350 camper's Avatar
e350 camper
4th Gear
From what I’ve seen online is you take the bolts out of the OBD connector and then the rest just pop out you may not be able to remove the vacuum lines and I wouldn’t but the other electrical connectors should be just push the tab and pull them off and you should be able to get to the radio space by leaving the vacuum lines connected in the dash pulled away far enough on top of the steering column to get to the radio mounting hole
husqvarna
May 23, 2022 11:10 AM
WB4IUY
Aug 7, 2016 02:06 PM
Hephaestus
2004 - 2008 F150
Apr 11, 2013 02:42 PM
dadirtydogg
2004 - 2008 F150
Dec 8, 2007 07:14 PM
