Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
1989 E350 Motorhome G3 Swap
Old Aug 16, 2025 | 10:26 PM
Jomorave86's Avatar
Jomorave86
3rd Gear
Just joined the site hoping someone here will have an answer for me, I have a 1989 E350 28' Fleetwood Jamboree class C motorhome with a 460 efi. I decided to fix a squeal I've been getting at startup. I figured out it was the alternator, so I started digging into it. I got to the point where I realized that the plug that houses the 2 heavier gauge black wires and one white wire isn't actually a plug. It looks like a plug but is molded into the alternator case. As I researched what I was looking at, I found out that I currently have a G2 alternator, and swapping to a G3 would be a wise thing to do. Currently, I have the old alternator/harness laid out trying to figure out where everything goes and what it does before I move forward. I have the 2 black wires and one white one coming out of the alternator, 2 wires going into the plug that came out of the regulator on the back of the alternator, 2 heavier wires that were butt connected to the next harness (white arrow), a round plug with 3 terminals (black arrow), and finally 3 wires that connect to the starter solenoid. The G3 swap looks easy enough. I understand that the current harness would be replaced by the G3 wiring setup. My problem is that I don't know what to do with the round plug and the 2 bigger wires that were connected to the next harness. I'm guessing that the wires have something to do with the house battery. I understand that the swap will lose function of the ammeter, which is fine. I'd just like to retain the rest of the factory functions of charging both the house and cab batteries. Hopefully someone here can tell me what I'm looking at. Thanks!
Kenneth Maddux
Electrical Systems/Wiring
Apr 2, 2023 06:18 PM
xenophone
16
Jul 29, 2021 09:59 AM
Dillon.Cobb
Feb 18, 2015 08:56 AM
handyjohn
Aug 3, 2014 11:35 AM
camperspecial65
Jul 3, 2010 08:32 PM
