98 Ford Expedition - shift lever stuck in Park - ignition issue.
Old Mar 12, 2025 | 06:10 PM
AKAJackson's Avatar
AKAJackson
Trailering
My shift lever has been stuck in park and I've been trying to figure out what's causing the issue. I had to disconnect the shift link cable from both ends and pull the shift lock actuator out of the way before I discovered it has something to do with the ignition. If I pull down on the shift lever while putting my key in and rotating it forward to the run position all of a sudden it is able to move through the whole gear selection area.
Does this mean the ignition module needs to be replaced or would it be something else further into the steering column? I'm surprised that the ignition itself gets in the way of the shift lever.
Old Mar 22, 2025 | 12:31 PM
Ol' Grouch's Avatar
Ol' Grouch
The shift lock is combined with the key cylinder. If you turn the key to release the lock, it unlocks the the column. You are pressing the brake pedal aren't you? If the brake light switch is bad, or going out, it won't tell the interlock to release the shifter. This is a safety device descended from the early 1970's when Fords had a bad habit of sometimes slipping into reverse while idling. I had a 1973 Maverick that I was warming it up one winter and it took off on me.
My '04 Expedition will sometimes lock the key where it won't turn. The locking sprag is sometimes the culprit there. If you pull in at an angle and shut the ignition off then release the steering wheel, it will try to straighten but the lock will hold it. The pin will engage on the sprag but the pressure won't let it release. You can sometimes get it to release by rocking the steering wheel back and forth while turning the key. I taught that to my niece when I was teaching her to drive. She gave me the dirtiest look but the lesson took.
AKAJackson
Mar 20, 2025 02:10 PM
AKAJackson
Mar 12, 2025 06:00 PM
AKAJackson
Mar 10, 2025 01:16 PM
trakman
Nov 9, 2004 10:49 PM
Ron Crawford
1978 - 1996 Big Bronco
Dec 16, 2003 11:30 AM
