windshield Resevoir is full but dashboard says emptyy
Old Feb 6, 2025 | 02:22 PM
yarbrob1's Avatar
yarbrob1
2nd Gear
Talking windshield Resevoir is full but dashboard says emptyy
I have purchased a new windshield reservoir and filled it. The water flows perfectly to the windows. The same fault comes up after 15 seconds of starting the car "windshield reservoir is empty". I can reset the dashboard information and the fault goes away until I start the car again. Does anyone know if there is something other than the reservoir connections that must be addressed?
The new reservoir came with a new pump and a new "water gauge" and this is the second new reservoir that I installed. There are two electrical connections. One for the pump and one to monitor for water in the reservoir. All wiring looks to be good.
2005 Ford Expedition Eddie Bauer
Old Feb 7, 2025 | 07:27 AM
alloro's Avatar
alloro
You might not be getting a ground to the circuit. According to the FSM, the ground (G101) is located on the RH side of the radiator.
See the attached PDF.
File Type: pdf
Old Feb 12, 2025 | 02:34 PM
Pickupmanx2's Avatar
Pickupmanx2
What part/s did you order..? I have a 98 Expy and the pump wont pump and the reservoir has a crack up high, I want to rplc the whole thing.
TIA
Old Feb 12, 2025 | 02:58 PM
yarbrob1's Avatar
yarbrob1
2nd Gear
Ebay:
For Ford Expedition 2004-2006 TRQ WWA62682 Windshield Washer Fluid Reservoir
Old Feb 12, 2025 | 04:45 PM
Pickupmanx2
Thanks, for some reason I didn't think to hit Eprey 👍
Anonymous12
Feb 21, 2024 11:02 AM
message
6.7L Power Stroke Diesel
Jun 28, 2022 06:21 PM
johnmel59
Jan 15, 2014 10:59 PM
Tommy1994
Aug 7, 2012 07:26 PM
deisele75
Dec 18, 2005 02:01 PM
