7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
7.3 Godzilla in a GT40
Old Dec 12, 2024 | 08:48 PM
philips's Avatar
philips
At the PRI show.
Old Dec 12, 2024 | 10:13 PM
Charlie98's Avatar
Charlie98
When do orders open up for THAT?!?!
Old Dec 13, 2024 | 07:08 AM
FishOnOne's Avatar
FishOnOne
I like it...
Old Dec 13, 2024 | 08:04 AM
67_4_ME's Avatar
67_4_ME
Now that Ford Performance is offering a 7.3 block without the deck groove in between the cylinders, I sure we're going to see more higher horsepower Godzilla's. Based on a couple YouTube videos I watched at least one (there was mention of two others) aftermarket vendor is working on new heads. The future looks good for the 7.3.
Old Dec 13, 2024 | 08:54 AM
OBS460's Avatar
OBS460
With those slits the block is basically a throwaway. Brian Wolfe mentioned before that you can't go overbore very much without running into too thin of a cylinder wall so they basically designed it to not be rebuildable that way. Planned obsolesence.
Old Dec 13, 2024 | 09:07 AM
67_4_ME's Avatar
67_4_ME
You may want to watch the latest Revan/Brian Wolfe video. Using the original block he's been testing with, they are on the cusp of a N/A 1,000 HP stock block, crank, and heads. Granted they all have been reworked, and the cubic inches are not 445.
Old Dec 13, 2024 | 02:03 PM
67_4_ME's Avatar
67_4_ME
This is the new block
Old Dec 13, 2024 | 04:18 PM
Louisville Joe's Avatar
Louisville Joe
Are the production Super Duty blocks also deleting the slots now?
Old Dec 13, 2024 | 04:36 PM
67_4_ME's Avatar
67_4_ME
I don't think so. You can buy both blocks from Ford Performance. The block without the slits says in the title 7.3L GAS ENGINE RACE BLOCK.
Official Site of Ford Performance Parts - Mustang Parts, Crate Engines, Packs, Wheels, Superchargers, Racing Parts | Performance Parts Authority
Old Dec 13, 2024 | 07:57 PM
OBS460's Avatar
OBS460
I just watched the video about the 472CI Godzilla and it is 4.25 bore so .030 overbore from a stock Godzilla 4.220 and has a stock crank turned with a Honda rod journal to give it more stroke. I would bet you can't reliably/safely go bigger than .030 overbore with a stock block with the coolant cuts between the cylinder walls not to mention the cylinder wall thickness it starts with.
Old Dec 13, 2024 | 11:50 PM
Louisville Joe
That is consistant with what I have heard so far.
For some reason GM saw fit to bless the L8T 6.6L with what is essentially a low-deck LSX race block with the extra head bolts deleted. That block can take a .120" overbore naturally aspirated, but the bore spacing is less than a 7.3L, 4.40" vs. 4.65".
Old Dec 14, 2024 | 12:04 PM
67_4_ME's Avatar
67_4_ME
I agree with you about the overbore statement. My thought is if you blowup your stock bore and need to go .30 over you can do it. If you blow up again at .30 over, you need to look in the mirror and ask yourself if you're the cause.
Old Dec 14, 2024 | 10:20 PM
Louisville Joe
It's not like the old days anyway. Low tension piston rings don't wear the cylinder much, you might go 250,000 miles and not have enough wear to require more than a .010" clean-up. I wouldn't call the 7.3L block a 'throw-away', I think in most instances it would be rebuildable once.
SkySkiJason
Aug 3, 2024 03:05 PM
philips
Dec 10, 2023 04:57 PM
2021F250XL - Godzilla
Apr 27, 2021 07:52 AM
FONRDAY
Aug 15, 2020 05:23 PM
Jocaren
Ford Truck Parts for Sale
Nov 15, 2011 11:57 PM
