7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
Mechanics Feedback on the 7.3 Lifter Failure
Old Oct 14, 2024 | 07:53 PM
FishOnOne's Avatar
FishOnOne
Old Oct 14, 2024 | 10:51 PM
leadmic's Avatar
leadmic
What about the recall to raise the oil pressure? Also, he never mentioned you could install the SEMIC kit to raise the idle. I have seen his videos before and he seems competent, but being a Ford Tech you think he would have known about the idle oil pressure recall.
Old Oct 15, 2024 | 06:40 AM
Ford8502's Avatar
Ford8502
He lost me when he starts out saying the 6.2 was total junk.
Old Oct 15, 2024 | 08:46 AM
OBS460's Avatar
OBS460
This video is laughable. He says it is happening to tons and tons of 7.3s. He claims the idle oil pressure is 8psi. Where did he get this information? Must have been from people on the internet because he says 8psi is probably why this is happening then says bumping it up to maybe 10psi or 15 or 20 will probably help. What kind of mechanic is he? 10psi will probably fix it but 8psi is too low? We haven't seen A SINGLE gauge read the actual oil pressure that the variable pump makes and the TSB just says it could cause catastrophic engine damage it doesn't say what specifically that damage is.
More people trying to get views off of an over inflated issue. I will believe single digit oil pressure at idle when a REAL mechanic plugs a gauge into the sender port and shows that it is 8psi. I think he took the number that causes the gauge to read and thinks that is the actual pressure.
Old Oct 15, 2024 | 12:21 PM
leadmic's Avatar
leadmic
I know right? The 6.2 paired with the 6R140 was one of the most reliable platforms of any truck manufacturers in the last 20 years.
Old Oct 15, 2024 | 03:49 PM
explorerdriver's Avatar
explorerdriver
Not making his pocket any greener.
Old Oct 15, 2024 | 05:12 PM
FishOnOne's Avatar
FishOnOne
It appears there's dealers that don't know anything about that recall. Makes you wonder.
Old Oct 15, 2024 | 05:13 PM
FishOnOne's Avatar
FishOnOne
Reliable as an anvil
Old Oct 15, 2024 | 05:19 PM
FishOnOne's Avatar
FishOnOne
I wouldn't shoot the messenger. Most mechanics don't get feedback from Ford on failures that occur in the field and will speculate like we do here on the root cause. Look how long the cam phaser problem existed in the EB engines and the techs were told to install the same junk cam phasers for the repair knowing they will fail again, but never really knew the root cause.
Old Oct 16, 2024 | 02:53 PM
capt caper's Avatar
capt caper
I just got an automatic installed via wifi update. It didn't mention what was done. Just said Enhanced stability.
Old Oct 21, 2024 | 08:59 AM
saratoga2011's Avatar
saratoga2011
I already did this with Forscan. My 2023 sits at 20psi at hot idle and goes up to 65ish depending on throttle and load.
Have no idea where 8psi came from.
Old Oct 21, 2024 | 07:47 PM
FishOnOne's Avatar
FishOnOne
Was your 2023 20psi at idle a result of a Forscan change?
Old Oct 22, 2024 | 05:44 AM
B767capt's Avatar
B767capt
My 2024 7.3L service manual says the 8 psi is the minimum oil pressure at idle. I hope all of ours are higher than that.
Old Oct 22, 2024 | 08:32 AM
saratoga2011
No. Forscan can't modify that to the best of my knowledge.
Old Oct 22, 2024 | 08:38 AM
oceanrace's Avatar
oceanrace
From where is this output pressure taken? Is there an external tap available for a gauge or pressure sensor? 🤔
