Trying to find out 1949 VIN
Old Jun 3, 2024 | 03:57 PM
fvr4's Avatar
fvr4
4th Gear
Question Trying to find out 1949 VIN
Hi everyone,
I've been searching around google and this forum was one of the places with the most info, I've found images of decoders from those years and everything but I'm still having issues because it doesn't match up, so much that I'm thinking maybe there is something wrong with the purchase I made and I should try to back out before trying to ship it to myself in another country and possibly have it decomissioned by customs in the US before it even ships out? Guess that's possible no?
Anyways, the VIN is 97HC170125 but I looked it up online and it comes out as a 1959 Ford Fairlane 500 but if I only look up 97HC it does show a 1949 F1.
The last bit of info I found which sounds correct but I'm not sure is this:
"97HC is an f1 6 cyl 6 digit production number is what shows on the sn code breakdown I have."
"Sorry the 9 is 1949. 7H is 6 cyl an 8R would be the 8 cyl c is 1/2 ton the last digits are the sequence number. On my phone so sorry the first one was cut short."
and
"You are correct about it being a 49, but it is NOT the 9 that determines that, 9HC indicates the 6 cylinder 1/2 ton F-1. The 7 indicates 49-early 50, however the serial number being under 101,000 would indicate 1949.
97HC (under 1001,) = 1949
97HC (higher than 101,000) = early 1950
98HC = late 1950
7HC would be a 1947 6 cylinder 1/2 ton"
I am attaching everything I found but I am honestly still a bit confused and would appreciate if someone with the knowledge and experience would clarify it a bit more? or confirm what that post text I found above this says.
Old Jun 4, 2024 | 02:03 PM
52 Merc's Avatar
52 Merc
Man, you've got all kinds of mis-information there. Welcome to the forum. The truth is, you have a legitimate 1949 F1 Ford pickup serial number. It breaks down like this;
9=1949-1950 production.
7H=226 6 cylinder engine
C=F1 half ton pickup
170125=consecutive unit number, likely built late 1949.
You should also be able to find a series of numbers and letters hand stamped across the top of the firewall. That would be your production code, which would include the code for the assembly plant, color code, and month and day of assembly. If you can find and post those, and a picture would be great because sometimes they don't always look like what they really are, we can decode that for you further. Here's some examples.
Old Jun 4, 2024 | 11:42 PM
fvr4's Avatar
fvr4
4th Gear
Thanks for the reply!
The car was restored using part from other cars, the suspension is from a mustang, a 350 chevy v8 for engine, 700r4 transmission so there are no stamped codes anywhere. It has one of those eBay vanity VIN plates with the one I submitted which is the one registered on the title and shows up online but I just have no way to verify that from where I am so finding out if this was a correct serial number was one of my biggest worries. I still think I would have issues having it shipped to myself in Central America because there has to be a serial number on the chassis somewhere for it to be imported/registered for the first time legally.
Old Jun 5, 2024 | 08:00 AM
mtflat's Avatar
mtflat
Originally Posted by fvr4
Hi everyone,
You have done a lot of research! Unfortunately, this is the only list that pertains to what I believe is a car you want to buy/import. A 1949 Ford car 6 cylinder serial number should start with 98HA. Someone made up a Serial number tag for a truck and placed it on a rebuilt car. I would avoid this one as you will have trouble getting it thru inspection.
Old Jun 6, 2024 | 10:52 AM
fvr4's Avatar
fvr4
4th Gear
Hi, yeah, at the end I asked for my money back, another good looking one will show up sooner or late, thanks for the help!
50=F1sRBest!
Jan 22, 2024 10:54 PM
dwpirkeyjr
Apr 24, 2023 11:49 AM
VikingF1
Aug 13, 2021 12:36 PM
Vincent Miller
Mar 7, 2021 10:40 PM
eberf
Oct 28, 2016 07:49 PM
