Rear counter look up ford nos parts help
Old Jun 3, 2024 | 01:40 PM
bigwin56f100's Avatar
bigwin56f100
I need a EAA-6384-A
i already got one from Dennis Carpenter and it's wrong. Im looking for a NOS one
oh its a flywheel ring gear for a 215-223 or Yblock
Old Jun 3, 2024 | 01:55 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
What year? What transmission/clutch?
These should work for most. Yeah, not NOS, but these are 146 tooth ring gears that cross reference:
PIONEER FRG146NC:
https://www.summitracing.com/parts/pio-frg-146nc
https://www.autozone.com/drivetrain/...46nc/54593_0_0
ATP ZA572:
https://shop.advanceautoparts.com/p/...572/19260033-P
Old Jun 3, 2024 | 02:35 PM
56panelford's Avatar
56panelford
Will this do..
https://www.ebay.com/itm/33535529695...8AAOSwVKFmIWCt
https://mcleodautomotive.com/product/146nc/
Old Jun 3, 2024 | 02:41 PM
bmoran4's Avatar
bmoran4
That D2RY-6384-A has applications for many Ford V6 & V8 vehicles from 1984 to 2011. I'm not seeing it as viable for any earlier applications????
The second one is the already mentioned PIONEER FRG146NC.
Old Jun 3, 2024 | 04:12 PM
bigwin56f100
The one from DC is about .150" too small I don't want anything else unless it's in a circa 1950s Fomoco box
honestly I think I have a couple nos ones here but for the life of me I can't seem to find them
here is a pic of the not so good ring gear
Old Jun 3, 2024 | 04:29 PM
bmoran4's Avatar
bmoran4
It seems you are not alone with this predicament: https://fordsix.com/threads/ford-223...19/post-675898
They purchased a correct gear from LSC Performance.
All my books this far show a single ring gear for all applications though... I'll have to look harder. Of course, your picture with the part number stamped is hard to argue with.
Old Jun 3, 2024 | 04:34 PM
bigwin56f100
I just decided to pull another ring gear off another flywheel. I was trying to use a specific flywheel (drilled for 10" clutch) but it had bad ring gear so I'll just pull a ring gear off a 11" clutch flywheel and install.
Old Jun 3, 2024 | 06:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might want to see if Al Suehring / Al's Ring Gears has them. https://www.suehring.com/
Old Jun 3, 2024 | 09:22 PM
pineconeford's Avatar
pineconeford
Knuckle Bandage Sales Rep
Kevin, the old timers around here who were too frugal to buy a new ring gear would remove the ring, rotate it about 30 degrees and put it back on. The engine would always stop in one of three locations on the flywheel, so the starter would wear out and chew up those sections. By rotating it, the starter would engage in a nice fresh area of the ring and whiz right past the boogered up areas.
I'm mentioning this in case anyone here can't find or afford a new ring gear.
I use the freezer/oven method of fitting the ring back on the flywheel. Once I brought home some dry ice from work and it worked great.
Tom
Old Jun 3, 2024 | 10:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Also a common trick to flip the gear, so the starter hits the "fresh" side as it engages.
Old Jun 4, 2024 | 07:03 AM
bigwin56f100
Yes "flipping" the gear and "rotating " the gear were both discussed with the customer and they didn't want either option
CarolinaRanger
1983 - 2012 Ranger & B-Series
Dec 17, 2014 08:56 AM
1951flatheaddave
Jan 3, 2012 09:59 PM
Highboy4x4
Aug 15, 2009 08:36 PM
MECHANICTIME
Apr 22, 2007 11:25 PM
zwinstead
Jul 22, 2005 03:26 PM
