1997 F250 red fluid leak
Old Apr 13, 2024 | 07:03 PM
gg1968's Avatar
gg1968
I have a 97 PSD F250. I noticed a few small red fluid drips on the garage floor. I looked under the trans and it looks dry. Seems to be from the front if the engine. Could it be a leaking transmission line or possibly the power steering lines? Don't think the power steering is a red fluid though. Looks like tranny fluid. Any common areas to look over at “up front”?
Old Apr 13, 2024 | 07:19 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Either one. The power steering system uses Type F ATF. Clean it off to see where it is leaking.
Old Apr 13, 2024 | 08:12 PM
JJF20's Avatar
JJF20
Adding to the above..
Assuming auto trans, follow the two lines (rh side of trans) from the trans up to the cooler (lh side of radiator - could have an after market cooler installed in front of the rad too), could be a trans line leaking.
Power steering lines, pump, or steering gear box could be leaking too.
Old Apr 14, 2024 | 06:35 AM
manicmechanic007's Avatar
manicmechanic007
Pull back the steering lower shaft plastic boot from the line retainer and check the input of the steering gear for the leak
Yes, the power steering fluid is type F trans fluid on those older ones (red)
I replaced hundreds of those gear input seals with the gear still in the trucks and made some good dough
It paid 3.7 hours to remove the gear and replace the seals
You can do it in 40 minutes if you hold your mouth just right while fighting the snap ring with some good pliers
trevorrules
Jan 7, 2014 05:43 PM
bearpa
May 26, 2011 02:50 PM
FORDSDOWNER
Nov 29, 2007 11:06 PM
brad1982f250
Dec 1, 2005 11:22 AM
