Tank for our '56 Panel
Old Feb 4, 2024 | 09:59 AM
thomc's Avatar
thomc
No pic yet but I bought a custom aluminum tank for our Panel that is the right width & heighth. However, it is somewhat shorter than the factory tank and holds only 7.5 gallons. Fortunately the 500 Cadillac engine I will be using is pretty easy on fuel so I can live with it.
It has a typical 5 bolt universal sending unit. I hope to find a sender that will work with the factory gauge in the Panel. Can anyone recommend one? Thanks.
Old Feb 4, 2024 | 10:21 AM
Old F1's Avatar
Old F1
I have the same truck so that is why I am replying.
From a old and feeble memory I read somewhere (don't have a clue where) I vaguely remember something about our fuel gauges having some kind of special circuit that does not use ohms resistance as the normal sending units do. (Or maybe that was on the submarine, or air plane, or tractor, website). If that is so, a list of senders would not help, so if that is right, retrofitting the original sender wold be the only option.
I am using aftermarket gauge and sender. Time to walk the dog, ... if I still have one.
Old Feb 4, 2024 | 10:26 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
The stock sending units (and you must use a stock one, not an aftermarket one) use a 6 hole pattern. Unfortunately 56 is a 1 year only 12V King-Seeley distometer setup (not ohms/resistance as one may expect!!)
As for physical constraints, these adapters may possibly be made to work in reverse with a stock sending unit. Expect to have to adjust the rod for your tank.
https://www.speedwaymotors.com/Speed...late,5865.html
https://www.tanksinc.com/index.cfm/p...rod/prd344.htm
However, it may be better to find a stock looking fuel gauge with ohms/resistance guts and pair it with an appropriate more common 5 hole sender. Maybe you can grab this one which is 32 Ohms Full, 240 Ohms Empty and find a matching sender:
https://midfifty.com/item.php?INV_ID...uge-56-squares
Old Feb 4, 2024 | 11:46 AM
Old F1's Avatar
Old F1
Originally Posted by bmoran4
Unfortunately 56 is a 1 year only 12V King-Sealy distometer setup (not ohms/resistance as one may expect!!)
Ah ha, yes right, Is that the same as the the Higgs boson elementary particle theory ? (just kidding, ... but gloating like a teenager on his first date)
Old Feb 4, 2024 | 02:52 PM
thomc's Avatar
thomc
Sounds like I might use a kit like the one from NAPA that I used in my Studebaker truck, that included the sender, matching gauge, and a panel to mount the gauge under the dash. I would like to try one of the cast aluminum panels that were made to fit a '56 dash and use aftermarket gauges. I saw one in the swap meet at the F100 show in Pigeon Forge, or Sieverville, TN last September but the seller wanted $150, with no gauges and it had some damage so I passed on it
Old Feb 4, 2024 | 02:59 PM
abe's Avatar
abe
When I first saw this thread title I thought it said "Thanks for my 56 panel." LOL
Old Feb 4, 2024 | 05:59 PM
Old F1's Avatar
Old F1
I worked for two months to get the gauge working on my current project. (other make) This what finally had to happen.
Old Feb 5, 2024 | 09:45 AM
bmoran4's Avatar
bmoran4
If you want to dig into it, I'll refer you to this post here that goes a little more into detail: https://www.ford-trucks.com/forums/1...l#post21076519
slowpoke17
13
Aug 11, 2022 10:21 AM
Sgtnomore
13
Jul 7, 2022 10:36 AM
tsmithbonterra
1947 and Older Ford Trucks
Dec 26, 2021 02:25 PM
thomc
Feb 20, 2021 06:44 AM
tinman52
Aug 4, 2014 11:43 PM
