Lousy Mileage 2006 Escape Hybrid
How many miles?
How old are the spark plugs (my first guess)?
When did this start?
Have you made any changes?
Driving habits changed?
Winter fuel is in full effect but since we odn't know your 'normal' mpg, we cant determine if this could be part of it.
I would also recommend using Seafoam in 1 or 2 tanks of gas to clean the injectors.
I’m a bit surprised as this is the best mileage that I have seen from this vehicle as all summer it was around 29 mpg highway and 27 mpg city.
I had given this car the Seafoam treatment last July and at that time had seen a jump to the 29 mpg level together with the new air filter.
I’m wondering whether to attribute this to cleaning of the injectors, or perhaps cleaning of valves as the escape hybrids use an Atkinson cycle engine for which the intake valve closes after top dead center, pushing some air/fuel mixture back into the intake manifold.
I had been learning that the larger, direct injected engines would have carbon build up on intake valves which reduces their mileage due to not having the gas detergents directly flushing the valves.
prior to my has oil change, I had also added Seafoam (1 oz per quart) for ~100 miles prior to the oil change but didn’t see any improvement from that. This was just preventative as the engi only uses about a quart of oil in 5000 miles.
This led me to question if a stuck thermostat might cause low gas mileage… it turns out that it can.
I found a video on changing the thermostat housing on YouTube.
one of the commenters had the following to say…
From YouTube comments
And another video from Makuloco that removes the radiator fan for better accessibility.
https://youtu.be/VNcRPxGXCz8?si=Msqvnb2I1_UvBPZZ
I replaced the thermostat and find that the hybrid function now engages regularly at stopping and starting where as previously it engaged only in summer with engine fully heated. The heat for defrost and interior is now restored and working well.
I was still concerned that mileage was not 31 highway and 36 city as I was still getting around 27 for city and 29-30 for highway gas mileage.
I reviewed cleaning the throttle body and intake on YouTube and performed the removal of the throttle body and intake manifold to as far as I could reach. Then reassembled and used a can of CRC brand of spray carb cleaner to further clean the t take manifold and valves by spraying the cleaner into the throttle body intake with the engine idling at 2000 rpm as recommended on the can. (2000 rpm seems to be the normal idle speed of the engine when charging the HV battery so took no special effort on my part).
Gas mileage for city driving has improved. I am now getting 30 mpg city and 31.3 mpg highway.
I am still interested in anyone’s advice as how I might get closer to the upper limit of 36 mpg for city driving.
