So question out there guys.
I installed some aftermarket clearance lights on my truck and tied them into what I thought was the day time running lights.
when I got to lock my truck and the light switch is on auto, the clearance lights stay on. Even after the lights have turned off on the truck. Have to go back in and turn the switch to off to get them to turn off. Would like to keep my switch in auto and have them all turn off the same time. I hooked to the white with violet stripe for the DRL.
suggestions???
There may be a small 2 pin connector behind the passenger A post trim that would attach to factory clearance lights. plugged in there they should function the same as factory lights.
