3 on tree - issues shifting from 1st to 2nd...
Old Jul 29, 2020 | 04:40 PM
jackderby22's Avatar
jackderby22
I'm having sporadic issues when shifting from 1st to 2nd... (3 on tree)... It sometimes gets stuck in-between shifts... I have to pull over to almost a full stop, drop it in first again and start over... I tried to double clutch it when this happens but it doesn't seem to help... If I shift it really slow and at a really slow speed it tends to work okay... Can anyone offer suggestion's on what to look for?? Thanks in advance!!
Old Jul 29, 2020 | 04:55 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Here's some info from ND on the most common cause. It's a good place to begin, at least.
https://www.ford-trucks.com/forums/8...ml#post7564698
Old Jul 29, 2020 | 05:10 PM
jackderby22
Awesome!! Thanks for the link!! Part numbers and everything!
Old Jul 29, 2020 | 05:23 PM
john jamieson's Avatar
john jamieson
If you don't have one already, Get a shop manual for your truck. There is a procedure for adjusting the linkages.
Old Jul 29, 2020 | 07:10 PM
jackderby22
Will do... Thanks for the tip!
Old Jul 29, 2020 | 08:04 PM
Bert65's Avatar
Bert65
check to see if linkages are loose and worn. when I test drove my 65 I could no get it into 2nd. Owner open hood tapped on linkage and it worked. I had to rebuild them. Easy to do, but that was the issue. sloppy linkage
Old Jul 30, 2020 | 06:14 PM
chiefdave's Avatar
chiefdave
I had much the same issue. Replaced the lever isolation bushing and linkage bushings (2) and lubed the linkage (there is a grease zerk toward the bottom of the steering collum). Works properly now.
Old Aug 1, 2020 | 09:06 AM
jackderby22
Guys, thanks for the help! I'm going to dive into all these tips and start working it... The shifting issue between 1st and 2nd seems to be getting worse so it's time!! Thanks a bunch!!
New bushings ordered... (in case anybody else wants the link).... 9 bucks for the part, 10 bucks for the shipping!! lol....
https://www.dennis-carpenter.com/pro...D=&q=C5TZ7343A
Old Aug 2, 2020 | 11:14 AM
jackderby22
I looked for a grease fitting with no luck?? I'll check again...
Old Aug 2, 2020 | 11:38 AM
chiefdave's Avatar
chiefdave
Here is the location. It could be covered with crusty old grease or broken off.
Old Aug 2, 2020 | 12:36 PM
jackderby22
yours looks a bit different than mine?? I got underneath as well... Wish there was fitting...
Old Aug 2, 2020 | 12:54 PM
djtaylor's Avatar
djtaylor
My '65 doesn't have a grease fitting either (I had to go out to the garage and check).
Old Aug 2, 2020 | 12:57 PM
jackderby22
Thanks!! Seems like a good place to have one!! I'm thinking maybe I can add one...
Thanks again!!
Old Aug 2, 2020 | 02:45 PM
Fathumb's Avatar
Fathumb
I have the same issue with my 65. If I am not careful I’ll stick the transmission when shifting from first to second.
i took a picture of my my shifting rods. I noticed my first/reverse rod is lacking what appears to be a bushings when comparing it to my second/third rod. Am I correct, or is this actually ok?
could this be my problem?
Old Aug 2, 2020 | 06:36 PM
jackderby22
Fathump, I'm no expert (far from it) but my guess is the problem is with bushings on top... I ordered new ones yesterday so once I get them installed I'll report back... That said, when I can I'll take a better look at what have below and let you know.
