7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
2022 E85 7.3 Coming
Old Jul 10, 2020 | 10:37 AM
karlrmac's Avatar
karlrmac
2022 E85 7.3 Coming
I was reviewing some docs and see that there is an E85 7.3 in the pipeline for 2022. Just in case anyone is interested.
https://madocumentupload.marketingas...80ef7&v5=False
Old Jul 10, 2020 | 04:08 PM
67_4_ME's Avatar
67_4_ME
Thanks for posting! I like looking at those future documents.
Old Jul 13, 2020 | 01:27 PM
super 6.8's Avatar
super 6.8
If nothing else you get upgraded fuel components.
Old Jul 13, 2020 | 09:18 PM
nick112288's Avatar
nick112288
Open up even more power opportunities with those coming blower kits!
Old Jul 15, 2020 | 06:13 PM
Louisville Joe's Avatar
Louisville Joe
At least in the E series. The 6.2L is E85 capable now, maybe we won't see an E85 capable 7.3L in the Super Duty until the 6.2L goes away.
Old Aug 18, 2020 | 12:23 PM
GNR22's Avatar
GNR22
According to that power point, this will be true on the E-Series, but nothing in there about the F-Series getting ethanol capability, unfortunately.
I had figured that the 7.3L was already E85 capable, pretty disappointing that this isn't the case.
Old Aug 19, 2020 | 07:46 AM
acadianbob's Avatar
acadianbob
So . . . you actually burn E85? And like it?
Old Aug 19, 2020 | 08:05 AM
Akley88's Avatar
Akley88
the only reason i would want to run e-85 is if the engine is modified with something like an aggressive tune or a blower. other wise your just gonna burn fuel faster on a stock engine.
Old Aug 21, 2020 | 05:25 AM
Drothgeb's Avatar
Drothgeb
I can see running E85 with forced induction or alcohol dedicated high compression engine. Otherwise, I don’t see the point. When I have time, I go well out of my way to buy ethanol free gas.
Old Aug 24, 2020 | 06:47 AM
GNR22's Avatar
GNR22
Yes and yes. I burned nothing but E85 in my daily driver F150 for the first 3 years that I had it. It worked out to be cheaper than running regular 87 octane. Price of E85 then jumped up and gas prices came down, so it was no longer the more cost effective route. Prices have normalized again, so it would be worth it to run E85 again, but there is no longer a station close enough to me for it to make sense to run it now.
I also run E85 in my '94 F350, but that's a pretty high compression motor.
Old Aug 24, 2020 | 07:37 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
Running around empty with E85 may work but if your loaded or pulling a load it's a no go for me, I tried it in my 6.2 one time pulling and that was enough.
Denny
Old Aug 24, 2020 | 07:43 AM
GNR22's Avatar
GNR22
Denny
For what reason? Fuel consumption?
Old Aug 24, 2020 | 07:52 AM
rvpuller's Avatar
rvpuller
Fuel consumption and loss of power, I've used both regular fuel and 10% with no noticeable difference but with 85% there was a big drop and that was with mixing it with what was in the tank. I finished the tank off unloaded and it wasn't bad it was just with the trailer in tow.
Denny
Old Aug 24, 2020 | 02:38 PM
Louisville Joe
Ford must not have a clue how to calibrate an engine running on E85. My old 5.3L Yukon runs better on E85, and the engine specifications show a H.P. and torque gain on E85. GM flex fuel vehicles advance timing significantly depending on how much E85 is in the tank. Maybe Ford doesn't bother? Fuel economy is worse on E85 though.
Old Aug 24, 2020 | 05:00 PM
ATX SD's Avatar
ATX SD
Denny
It may be that you didn't run enough E85 for the alcohol sensor to decide to switch to high-E computer settings for timing and flow. The manual says to put in a full tank and not mix it, so the sensor can pick up the E85 content value.
