I have a 95 lighting bone stock 213xxx ran fine till yesterday went to restart wouldnt start have no spark no fuel... Heres wht ive done
checked fuses...swapped coil and icm/tfi module...new ignition switch elctric part.... Coil gets juice but assuming computer aint grounding it cause have no spark fuel pump will work when I bypass relay but truck still wont start cause injectors won't fire either I,need ideas
Lots of issues are pointing to the ECM, so I'd start by double checking all fuses using a flashlight to make sure you can see them real good.
I've got same truck one time mine did that and it was a bad pin connection in a plug on drivers side fender next to firewall ,it sends signals to distance and ingn.
