Need help finding a pulley
Old Nov 7, 2019 | 02:10 PM
harleymsn's Avatar
harleymsn
As some of you know, I installed the JAG IFS in my 51 F1 and am still running the flathead. Here is my issue, I found an old Speedway alternator mount that attached to the head and have the PS pump installed. The problem is that the pump has a 3/8" pulley, where I need a 3/4" pulley. I've tried every option to find a pre-made pulley to fit, but it appears that it does not exist.The press fit hub on the originally pulley is a bolt on hub, so I am trying
to find a pulley that I can modify to fit the hub onto.I have an old fan hub that I could take apart and have a machine shop cut it apart and weld a solid center into it and the drill out for the hub. But I have to destroy a good fan hub assembly that someone may need.
Old Nov 8, 2019 | 03:03 AM
fish pond's Avatar
fish pond
McMasterCarr
Maybe you could buy one and have it modified ?
search for "pulley" many manufacturers out there, rather than at the truck parts store.
good luck, many machine shops could help.
Greg
Old Nov 8, 2019 | 06:06 AM
harleymsn's Avatar
harleymsn
Greg
I've actually contacted a few different manufacturers, so far none could help. As I mentioned in my original post my plan was to go the machine shop route, but I thought I would ask for other options here first.
Old Nov 11, 2019 | 07:44 AM
petemcl's Avatar
petemcl
Have you tried running the ⅜” belt with the current pulley? Mine works fine but the belt needs to be tight.
Old Nov 11, 2019 | 08:30 AM
harleymsn's Avatar
harleymsn
Are you running that on the fan pulley on the crank? It just seemed to me that running a 3/8 belt on a 3/4 pulley would not work. Of course I know a lot of people don't realize that the crank pulley has two different sizes (5/8 for water pumps/generator and 3/4 for fan) and run 5/8 belts on both.
Old Nov 11, 2019 | 08:45 AM
petemcl's Avatar
petemcl
Fan pulley.
Old Nov 11, 2019 | 08:55 AM
harleymsn's Avatar
harleymsn
I suppose that I could try that. BTW, I just checked and the Jag pump uses a 12.5mm wide belt, which actually translates to a 1/2". 1/2 x 50 ribbed v belt is a common size belt so that would un-complicate the issue.
Old Nov 11, 2019 | 11:15 AM
ynot321AB1's Avatar
ynot321AB1
I have the double wide belt hub pulley off of the crankshaft of my 239. It is slightly bent but if you are interested, give me an email addy and I can send you a pic. If it is the one that you are looking for, I would take $70.00 for it and you pay the shipping from zip 72927, ( Arkansas)
Old Nov 11, 2019 | 11:26 AM
harleymsn's Avatar
harleymsn
Thanks, but I was looking for a pulley for the PS Pump. I actually have a couple extra crank pulleys.
Pellas
Jul 3, 2014 08:34 PM
fontime
Feb 23, 2011 03:41 PM
bigwill250
Oct 4, 2006 09:11 PM
maa139
Garage & Workshop
Jan 6, 2006 10:47 AM
176ford
Mar 30, 2004 09:18 AM
