1967 brake bolt question
Old Nov 4, 2019 | 02:10 PM
Carpediem930's Avatar
Carpediem930
So I have this bolt w/castle nut. It is one of the four bolts that hold the front driver side drum onto the spindle assembly. One of the two bottom bolts (the longer ones) has the threads at the very end slightly mushed from some idiot hitting it with a hammer to free it (I plead the fifth), therefore not allowing the castle bolt to screw on. Is there an easy fix for this? Or do you know where I might find replacement bolts (and what the particular bolt is called, if it has a specific name?).
Old Nov 4, 2019 | 02:36 PM
85e150's Avatar
85e150
Go after it with a file or a grinder then a file. Or find a die of that size to run on to it. Serving suggestion.
Old Nov 4, 2019 | 05:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No year, no model, no series. How do you expect anyone to help you?
Old Nov 4, 2019 | 05:56 PM
Carpediem930
Sorry. It’s a 1967 F100 2WD
Old Nov 5, 2019 | 02:17 AM
NumberDummy
Old Nov 5, 2019 | 05:24 AM
'65Ford's Avatar
'65Ford
Take it to a hardware store to find size and pitch. Buy all new bolts and castle nuts. Drill hole in bolts where needed. I like McMaster Carr online, but any well stocked hardware store should have castle nuts. Make sure to get the hardness rating same as original bolt or at least grade 8.
Next time, protect the threads by removing the castle nut and partially screwing it back on facing the wrong direction before hitting the bolt with a hammer.
Old Nov 6, 2019 | 09:59 AM
Carpediem930
Thanks for the website suggestion, I'll definitely be browsing that in the future. I did learn about the reverse castle nut technique, unfortunately not until after the damage had been done. Oops.
This is what I ended up doing, and after spending some quality time with my file, I fixed it up.
Tyler S
Sep 25, 2014 12:14 PM
jerryst
Oct 25, 2011 01:37 PM
69ford99
1978 - 1996 Big Bronco
Nov 13, 2006 05:07 PM
smitty7
1983 - 2012 Ranger & B-Series
Feb 16, 2005 02:34 PM
MustangGT221
Oct 6, 2003 10:41 PM
