My old girl has finally start to shake her ***. 151K
2000 F350 SD 4x4 V10
Replaced calibers rotors brakes, New Tires
New Shocks all around, Stealership wants a treasure chest; recommended replacing the ball joints and drag link.
Everything is pretty tight in the front; scratching my head not many other parts to the front. Any ideas would be helpful.
‘So DW is the result of loose or worn parts. CA, TRE, BJ, DL bushings that are worn can contribute to DW. Check your pitman arm for torque and signs of wear or movement. IF you have a steering stabilizer on the truck remove it, as it will often mask certain areas of wear. Lifting the truck off the ground and checking for obvious signs of wear may help if they’ve gotten really bad. I’ve lifted the truck up at the axle then after an initial inspection ,keeping truck off the ground, slightly lifting the truck off the axle (basically unloading the suspension) and look for additional areas of wear. However, often you have to take parts off to truly determine the level of deterioration. A bushing can look good installed but once removed the wear becomes obvious. I’m of the mindset that if I took it off I might as well just replace it at that time. You may have to wait until the symptoms get worse in order to isolate a particular part.
If you remove suspension parts remember not to torque them with the truck in the air. You can reinstall parts with it lifted but put the truck back on the ground before torquing bolts/nuts.
I actually had it in my 1996 F250 that had a king pin Dana 60 SAS. It turned out to be an unbalanced wheel/tire. I think it was just one but can't remember exactly.
Honestly, have never heard of death wobble on a leaf spring front.
You'll know if it ever happens to you... Every vehicle with a solid front axle has the potential to do it. It can be more than just one thing that causes it. Scares the crap outta you when it happens.
I agree, I thought it was only a coil spring front end issue, not a leaf spring issue. I've got 375k on my '00, have replaced the ball joints a couple of times now and never had a death wobble. My '13 just rolled 70k and it had it to the point of being violent before I did the ball joints, track bar joints and front tires. It still seems to be right on the edge of doing it on some bumps. The '00 has never even faintly showed a tendency to wobble.
Maybe worn out leaf spring bushings. Death wobble isn't nearly as common on leaf sprung axles because the leaf springs center the axle and keep the it from moving back and forth, unlike a coil sprung axle that has to rely on a track bar to keep the axle centered.
