Nevada Chapter Join Chapter, Leader: FordTruckNoob
Help 79 f250 won’t stay running
Old May 4, 2018 | 08:31 AM
Timbid's Avatar
Timbid
so when I start my truck up in the morning it runs for a good minute but then when it’s warmed up it dies. Any ideas what it is?
Old May 4, 2018 | 04:15 PM
kermmydog's Avatar
kermmydog
Not to be a wise guy but fuel, spark & air. Which one quits when it dies. Is it a stock engine 351M or 400 were the engine options for 79.
Old May 4, 2018 | 05:17 PM
Timbid's Avatar
Timbid
No it’s stock 460 the towing option for the year and yes I know the three. There’s spark and I think I was able to diagnose it to a fuel issue. There may be a jet or port that is clogged starving the engine. Going to pull the carb off again and re clean it. A little more in depth
Old May 5, 2018 | 07:37 PM
kermmydog's Avatar
kermmydog
If it has a mechanical fuel pump hook a vacuum gauge between the tank & pump You should have vacuum to pull gas to the pump. Then check Fuel pressure between pump & carb. Try dumping some SeaFoam or the Super Tech (Walmart Brand cleaner that is the Seafoam at Walmart Price about $2 cheaper than name brand.)
Old May 5, 2018 | 11:14 PM
Timbid's Avatar
Timbid
so it has an electric pump but I think I found the reasons for the issue. The was a bent step up rod
Old May 6, 2018 | 04:01 PM
kermmydog's Avatar
kermmydog
That is great you found the issue.
Do you have an aftermarket Electric pump external or is it in tank?
I have had more issues with FORD in tank ELECTRIC PUMPS than all others.
I have found DELPHI electric pumps are the best.
Timbid
May 4, 2018 05:36 PM
1984Ford300six
15
Aug 23, 2014 08:54 AM
riley3d
Dec 29, 2005 06:35 AM
wideopen23
Feb 27, 2005 06:28 PM
Jekylltamer
Oct 3, 2004 08:25 PM
