15" X 7" rim offset on a Explorer rear on a F-100
Old Apr 18, 2018 | 08:23 PM
F100supercrew's Avatar
F100supercrew
BACK SPACING for 15" X 7" rim on a 1997 Ford Explorer disc brake rear installed on a 1954 Ford F-100 and what tire size did you use--- pictures-- Thanks
Old Apr 18, 2018 | 11:38 PM
pappacrunch's Avatar
pappacrunch
This is what I went with. Mine is a 2001 Explorer rear end with disk brakes. My tires are just a hair to wide and every now and then you can hear a squeal when the rubber hits the bed wall. A 3.5" backspace would prevent that.
Wheel Vintique Series 12 15x7 4” backspace
Bolt pattern is 5 x 4.5
B.F. Goodrich Silvertown 225/75RX15 - 2.75" WW
Section Width 8.8 Inch
Height/Diameter 28.3 Inches
Old Apr 19, 2018 | 09:04 AM
monkey-1's Avatar
monkey-1
Sexy ride!
Old Apr 19, 2018 | 11:15 AM
petemcl's Avatar
petemcl
You really need to measure your truck yourself. Not all of these trucks are the same nor are the axles. It could be an expensive mistake.
Here is a link to a handy form that I used to order mine from Wheelsmith. theWheelsmith.net - Wheel Gemometry
chet_cowan
Mar 23, 2015 07:26 PM
Skydive80
Aug 20, 2012 01:30 PM
HEAVY100
15
Oct 24, 2011 04:12 AM
seanmconroy
Feb 19, 2011 11:51 AM
al37ford
15
Sep 11, 2006 06:54 PM
