Instrument Panel Wiring
Old May 16, 2017 | 10:38 AM
efingrn1's Avatar
efingrn1
Hey Guys - I am new to at this and looking for some insight. I just purchased a '77 Ford F150. Per the vin number, it was originally built with a 351W, but the guy I bought it from told me that it was a 460 engine. I can't find any identifying plates on the engine or under the hood. Can anyone help me to identify exactly what size engine it is? Any quick tips or tricks?
Also, I am replacing the chassis wiring harness and am redoing the instrument panel cluster. I have the original instrument panel connector but am having a difficult time finding the right open barrel terminal to fit. Is there a specific one I need, or can I use whatever I can get to fit?
Thanks for your help -
Old May 16, 2017 | 11:04 AM
Filthy Beast's Avatar
Filthy Beast
Look at the valve cover bolts (one cover only):
5 bolts: 332/352/360/361/390/391/406/410/427/428 (FE engine)
6 bolts: 221/260/289/302/351W
7 bolts: 429/460
8 bolts: 351C/351M/400
Can't help you on the terminals but I think some parts stores would carry 'em?
Old May 16, 2017 | 01:02 PM
efingrn1's Avatar
efingrn1
Thank you so much Beast!! You made it a lot simpler than i expected! (P.S. it is a 460 )
Old May 16, 2017 | 01:30 PM
Filthy Beast
You're welcome.
And Welcome to FTE...good people here
Old May 16, 2017 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Per the vin number, it was originally built with a 351W (impossible!), but the guy I bought it from told me that it was a 460 engine.
1981 was the first year that the 351W was available in F150/350 & Bronco. But it was installed in Econolines beginning in 1975.
4th digit of the VIN is the engine code.
H = 1975/79 E100/350 351W; 1977/79 F100/350 & 1978/79 Bronco 351M
A = 1975/79 E250/350 460.
J = 1973/79 F100/350 460.
351W = 6 valve cover bolts per side; 460 has 7; 351M (and 400) has 8.
1976/79 F100/350; 1976/80 Econoline & 1978/79 Bronco use a different instrument cluster back & printed circuit board with Oil/Amp GAUGES than they do with Oil/Amp WARNING LAMPS.
Korya
Jun 2, 2016 11:14 PM
sfeverall
Jun 10, 2011 09:00 PM
thenine
Aug 26, 2010 01:15 PM
elektrafried
Dec 28, 2006 03:47 PM
ranger74
Aug 3, 2005 03:36 PM
