Leak at Fuel Sender flange
Old May 15, 2017 | 09:39 PM
bhenders's Avatar
bhenders
Gentlemen,
I have a 77 F-100, 2-wheel drive, 302 with 3 on the tree. I am battling a leak at the fuel sender flange. I am using a fuel sender unit, gasket, and lock ring from Ecklers.
I was careful to turn the lock ring to full engagement so I am struggling to determine why the leak. (Only when tank is really full to I get the drip, drip, drip.) (I was also careful to make sure the gasket was properly seated.)
The Ecklers gasket and lock ring look a little flimsy, so I am wondering about finding original stuff. (The shop that I wanted to do the RENU process to my original tank through out the original gasket and lock ring when they could not fix my original tank.) I have a new tank.
This F-100 has the 18 gallon tank aft of the rear axle.
Bill,
I try not to take your ability to dig up part numbers and let us know what dealers might have stock on hand. Much obliged if you can work that magic for this gasket and lock ring.
Has anyone else ran into this ??
Old May 15, 2017 | 10:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes I have, so I always use a new gasket, and little solvent pruff RTV. Also make sure your mating surfaces are clean, and the lock ring is straight and not bent, same for the tank ring area. Did you do the tab bend to lock it trick?
Old May 15, 2017 | 10:47 PM
PapaBearYuma's Avatar
PapaBearYuma
The gasket is bought from Bronco Graveyard was square-cornered, and almost seemed too big, as you really had to press the sender down to get the lock ring seated. No leaks!
Old May 16, 2017 | 08:53 PM
bhenders's Avatar
bhenders
Thanks 77&79 F-250 and Papa Bear Yuma
Thanks guys! I will make good use of your info. I debated putting some sealer on the gasket, and now I will. I also knew that someone, somewhere would have an alternative to the dinky little gasket that came with my Eckler's fuel sender.
Thanks!
Old May 17, 2017 | 09:14 AM
HoustonDave's Avatar
HoustonDave
Ran into the same problem - the good news is that it only leaks when the tank is full. Another alternative for you - a #229 O-ring is the right size. Be
sure to lube the ring with something like grease or petroleum jelly so if the sending unit flange shifts, it won't distort and allow the leak to recur.
Old May 17, 2017 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
COAF-9276-A .. Fuel Sending Unit O-Ring - 2 3/8" I.D. x 2 9/16" O.D. x 1/8" thick / Available from Ford
1960/79 FoMoCo Passenger Cars; 1967/72 F100/350 with auxiliary fuel tank; 1970/79 Bronco & Econoline; 1973/79 F100/350 with mid-ship & aft axle fuel tanks.
Old May 17, 2017 | 06:00 PM
bhenders's Avatar
bhenders
Many thanks to all 4 of you ! The dentside forum cannot be beat !!!
RojoStar
Aerostar
May 16, 2016 07:58 PM
PRUSue
Jul 21, 2014 06:39 AM
junkyardkid2002
Nov 2, 2011 08:37 AM
JOHNSHO
Oct 17, 2011 11:01 AM
