Autolite 2100 to Clifford Adapter
Old May 4, 2017 | 09:15 AM
jack orchard's Avatar
jack orchard
Anyone know what adapter works with a Clifford intake to an Autolite 2100 2-barrel carb. Clifford web site says their adapter is not for Holley carbs (same bolt pattern).
The design of the Mr. Gasket 1933 gave me a vacuum leak at the edges.
Thanks again,...jack
Old May 4, 2017 | 11:25 AM
The Frenchtown Flyer's Avatar
The adapters I'm using on my Cliffords say Clifford on them and 2100 fit. Are you sure he didn't think you meant Holley/Weber 2Vs which is a different pattern?
You can make spacers if you have access to a band saw and a hole saw. I've used hardwood for spacers, when no EGR is needed. Or a scrap piece of composite counter top material. Or aluminum stock.
Old May 4, 2017 | 12:19 PM
jack orchard
Thanks, FTF:
The web site just says "Not made for Holley 2 brl carbs". If i can contact them, i will get a clarification.,....jack
Old May 4, 2017 | 05:27 PM
jack orchard
Larry from Clifford called me. Thank you, Larry.
NOTE TO LARRY: If my remarks are not correct, please correct me. I mean to be accurate.
He said the adapter is made for Weber carbs. Use with Holley 2 barrel carbs or any other 2 barrel carb will require mods to the adapter to fit and will result in poor performance - "flat spots, etc.".
Anyone have comments?.,...jack
Old May 4, 2017 | 11:43 PM
Brian_153624's Avatar
Brian_153624
I have been using the Mr Gasket adapter on mine without any problem.
Old May 5, 2017 | 09:08 AM
Originally Posted by jack orchard
Anyone have comments?..jack
nope
not me
I'm speechless
Old May 5, 2017 | 12:21 PM
1986F150six's Avatar
1986F150six
Originally Posted by The Frenchtown Flyer
nope
not me
I'm speechless
You say so, Sir, but when you do speak [share your knowledge on the forum], I am reminded of the old EF Hutton commercials:
https://www.bing.com/videos/search?q...FA65&FORM=VIRE
Old May 17, 2017 | 09:22 AM
HoustonDave's Avatar
HoustonDave
once acquired some printed circuit board scrap... glued multiple layers together, then made my cutouts with hole saw and bit on a drill press.Still leak free and working when I sold the Triumph years later. You think finding spacers for these is difficult, try obscure Brit-car parts...
Old May 26, 2017 | 03:31 PM
jack orchard
Results:
I ordered a Clifford two barrel adapter from the picture on their website. The adapter i received was an 08-1013W - W as in Weber. The bolt pattern is Weber only. The bolt pattern for the Holley, Autolite, Motorcraft 2 barrel carbs has been eliminated. Larry refunded my $68, but of course, i had to eat the shipping both ways. He still has not posted the correct picture on the internet site.
No more Clifford for me - EVER. (except at a swap meet)
jonny.redneck
Apr 23, 2014 04:43 PM
460
Nov 23, 2010 08:43 PM
1982fordf100
Dec 28, 2005 08:06 PM
f100guy
Jan 9, 2005 04:30 PM
