1964 F100 4x4
Old Oct 25, 2016 | 11:58 AM
Ferari's Avatar
Ferari
1964 F100 4x4
Saw this on Bring a Trailer and thought I'd share.
1964 Ford F100 4WD | Bring a Trailer
Old Oct 28, 2016 | 11:04 AM
oaklandford's Avatar
oaklandford
Very fair price, just a little to white for me.
Old Oct 28, 2016 | 12:22 PM
GenX66's Avatar
GenX66
Nice truck. Good price. All there other than maybe a rear step bumper. Good pics though for those guys out there piecing together a truck, good reference pics to compare what and where everything goes, etc...except battery...
Old Oct 28, 2016 | 12:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Step bumper would have been an aftermarket option, since Ford never offered them for these trucks.
Thru at least 1979, all rear bumpers were optional.
Old Oct 28, 2016 | 05:45 PM
1964FORDTUF's Avatar
1964FORDTUF
Theres something going on with that truck, its got a 2WD battery tray under the hood and also a 4x4 battery door in the floor...unless F100's came like that. Cant put a battery tray under hood of my F250 because pass side inner fender is different than 2WD. Or so it seems. I tried it, aint happening
Old Oct 28, 2016 | 05:58 PM
NumberDummy
Originally Posted by 1964FORDTUF
There's something going on with that truck, its got a 2WD battery tray under the hood and also a 4x4 battery door in the floor...unless F100's came like that. Can't put a battery tray under hood of my F250 because pass side inner fender is different than 2WD. Or so it seems. I tried it, aint happening
After reading this post, I looked at the ad again.
It's a 4WD conversion, probably by a previous owner.
The seller posted the VIN: F10CR510720
F10 = F100 2WD / C = 292 2V / R = San Jose CA Assembly Plant / 510720 = 1964, assembled March 1964.
So is the seller aware? There's no mention of a 4WD conversion.
Looking at the right side view, the front wheels seem to be too far to the rear, are not centered in the fender opening.
Edit: There's a pic of the Warranty Plate, the VIN begins with F11 = F100 4WD .. but the Warranty Plate looks brand new (possibly a Marti replacement).
So, the only way to prove whether it was originally a 4WD, is by the VIN on the title.
Old Oct 28, 2016 | 09:31 PM
1964FORDTUF
Its funky, theres no doubt about it!! Thanks Bill -
Old Oct 28, 2016 | 10:36 PM
aj64f100390-292's Avatar
aj64f100390-292
can u decode my warranty plate for me ,if u would..thanks in advance
Old Oct 29, 2016 | 09:45 AM
NumberDummy
Originally Posted by aj64f100390-292
Can you decode my Warranty Plate for me?
F10 = F100 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
446775 = 1964, assembled August 1963.
128" Wheelbase.
BM: B = Caribbean Turquoise / M = Wimbledon White.
F100 2WD .. 5,000 lbs. GVWR
C81: C = Medium Green Crush Vinyl & Medium Green Check Stripe Woven Plastic / 81 = 81B Custom Cab.
B = Borg Warner T-85 3 Speed Manual with Overdrive.
A2 = Spicer/Dana 44 Rear Axle / 3.92-1 / Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old Oct 29, 2016 | 10:58 AM
kjvforme's Avatar
kjvforme
Hey Bill might check the original post photos again, in the post it is a F11 not a F10.
Old Oct 29, 2016 | 11:00 AM
aj64f100390-292
thanks...wow an overdrive...i take it that is rare? how rare
Old Oct 29, 2016 | 11:29 AM
NumberDummy
I did look, and...
In the ad, below the BaT essentials, the seller listed the VIN as F10 .. The pic of the Warranty Plate shows it as F11.
Compare this Warranty Plate which looks like a "new Marti replacement" with the pic of the original Warranty Plate in post #8.
1964/65 US trucks used the same Warranty Plate.
Old Oct 29, 2016 | 12:05 PM
kjvforme's Avatar
kjvforme
One of the pictures shows the battery box acces plate in the cab.
Old Oct 29, 2016 | 12:08 PM
tripleframe's Avatar
tripleframe
As a general rule, worry about conversions when you see the newer '64-'66 styleside bed on a '64 or '65 F 100 4x4. Even without looking at a VIN #, most will not go thru all the trouble to locate the correct bed, cut the frame down and use correct steering wheel and column. I think the dual battery conversion is a great idea! Maybe it was a factory DSO job!
Old Oct 29, 2016 | 12:11 PM
kjvforme's Avatar
kjvforme
I guess the only true way to verify would be to look at the frame number.
