After removing the housing in my 1979 Ford F-150 351m I noticed I had a Windsor thermostat... After looking for quite along time I found the RT 139.... Is the the correct gasket ? What is the correct one if I have the wrong one thanks guys
When I was getting a new gasket, the two choices from autozone only differed by inside diameter, if nothing else, do the same and when you call the parts store make sure that is the same
Oh fancy gasket. It is not a 351W gasket at least. Looks to be the right one to me.
Looks the same as the "proper" 351m gasket. Many parts for the 351m and the 400 are the same. I say ask for the gasket for a 400 because Ford only made one 400.
To cause confusion, Ford made the 351 Cleveland, 351 Windsor, 351 Modified...
To be specific everything is the same between the 351M and the 400 save for the carb (calbration only) Cam (calibration only) and the reciprocating assembly. Otherwise they are the same engine.
The gasket in the pic looks like a Fel-Pro 35041T Perma-Dry. The regular one is a 35041. They are both listed for a 351M/400. The difference is the price. 35041T-$8.99.
35041-$1.99. Prices are Autozone.
It seems I'm getting back pressure through my cooling system is that a probably a head gasket ? I'm in the process of flushing the radiator to see if it's clogged.....
