Instrument Voltage Regulator IVR
Old Oct 17, 2016 | 10:50 PM
EP145's Avatar
EP145
Hi, So for the past several months my Temp, Fuel and Oil gages either read High, Low or just about right and all at the same time. I did a lot researcher on the cause and it seems to point to the instrument voltage regulator is going out. I found one at the JY and it seemed to work ok for a little while and it then it started to flake out again so its time to try something else out. I found on google a guy that made one using an adjustable step down regulator so I ordered the part Amazon.
https://www.amazon.com/Step-Down-Adj...words=de-swadj
Here is his web site, I will let you know how it works next week when it comes in.
ICVR - ???Gary's Garagemahal
Old Oct 18, 2016 | 07:53 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Thanks for the lead on this. I checked out this guy web site, lots of info to read up on.
Old Oct 18, 2016 | 08:49 AM
CelticOne's Avatar
CelticOne
Regular User
That's a great writeup on the installation at Gary's Gragemahal. Thanks for the info and looking forward to an update once installed.
Old Oct 18, 2016 | 12:31 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D1AZ-10804-A .. ICVR ~ Instrument Cluster Voltage Regulator (Motorcraft GR-513) / Obsolete ~ Available NOS & from auto parts stores.
1971/86 F100/350 & Bronco / 1971/91 Econoline // Misc. 1971/79 Passenger Cars.
Old Oct 18, 2016 | 05:33 PM
lalberts's Avatar
lalberts
Available thru LMC truck Dash voltage regulator. I replaced mine and got from LMCtruck.com
Old Oct 25, 2016 | 01:05 PM
EP145's Avatar
EP145
I received the voltage regulator a couple of days ago and found time to solder on the leds. First I took a 9V battery socket and cut it in half. Then I soldered the Black wire male socket on the VIN post, then soldered the Red wire female post on the Vout post. Last I soldered a wire on for the ground and put a ring terminal on the end. Now the colors are wrong when you use a 9V plug that has the wire already connected, what is important is that you put the male and female sockets in the right place. Today is a half day for my daughter so I half to stop now, hopefully I can install it tonight or in the morning.
I used a power supply to adjust the voltage to 5.5 volts.
Ready for install.
Old Oct 25, 2016 | 01:07 PM
EP145's Avatar
EP145
I wanted to see if I could dial the gauges in to read a little better, might work might not.
Old Oct 26, 2016 | 12:03 PM
EP145's Avatar
EP145
This morning I was able to install my new custom IVR and so far so good, all of the gauges point about were they should, not the temp gauge reading hot when the engine is only 170 degrees. If this works I can finally trust my fuel gauge!
I used some 3m double stick tape to attach it and placed some tape on the leds for piece of mind.
Old Oct 26, 2016 | 07:09 PM
lalberts's Avatar
lalberts
Just looked 24.95 on LMC truck For replacement original
Old Oct 27, 2016 | 12:31 AM
EP145's Avatar
EP145
I drove the truck all day and the gauges have seem to have stabilized and read the correct values or as close as stock gauges can. I count this as a win!
Old Oct 27, 2016 | 12:39 AM
robotunderpants's Avatar
robotunderpants
Nice Work! My temp gauge always reads just over cold. Some day I am going to take a look at it, but I have no idea where to start. I will probably replace the circuit board and the instrument cluster bucket at the same time. Any advice?
Old Oct 27, 2016 | 01:58 AM
EP145's Avatar
EP145
Well first off is it just your temp gauge that is not reading right? If so it's probably not your regulator because it will affect the temp, fuel and oil gauge. I would take an inferior red thermometer ( Harbor Freight has them for $30) and check to see what temp your upper radiator hose is reading, maybe you are running cold. If your not running cold start with changing your temp sending unit in the intake. If you are running cold change your thermostat it might be stuck open.
Old Jan 24, 2018 | 03:27 PM
ERNI3's Avatar
ERNI3
Hey EP145, looks like you are in AZ as well? What part of town? I'm out in San Tan Valley.
How's the voltage regulator working? Any reason you adjusted to 5.5v vs 5.0v?
Thanks!
Brad
Old Feb 13, 2018 | 10:18 AM
EP145's Avatar
EP145
Thanks!
Brad
Hi,
Sorry for the late response I haven't been on the site for awhile, I'm in central Phoenix. The VR has been working great if I remember I adjusted it to 5.5 to bring the gages to a more normal reading.
riggerparish
Dec 21, 2013 02:14 PM
vwfreak
29
Jul 15, 2012 04:49 AM
EL84
Aug 19, 2009 06:38 PM
JBronco
1978 - 1996 Big Bronco
Feb 10, 2005 03:38 PM
bronco2ok
Bronco II
Feb 20, 2004 03:57 PM
