1978 - 1996 Big Bronco
Parts interchange > Dash & Tilt column ?
Old Aug 10, 2003 | 06:44 AM
makemeknowit's Avatar
makemeknowit
Question Parts interchange > Dash & Tilt column ?
I am going to be getting my friends '93 F150 that is totalled and swapping the drivetrain (302 EFI/AOD, not AODE) into my '84 Bronco. I'm curious as to whether his dashboard and tilt column will go in my ride? Is this swap doable or a hassle that's not worth the trouble? What about just swapping the column if the dash is a pain?
Thanks again,
Mike
Old Aug 10, 2003 | 10:09 PM
chuck641's Avatar
chuck641
i dont think you will have a problem with the dash, if anything there may be a couple brackets to make or move. also the electronics and heat controls etc .. unless you just mount the controls from your 84 into the newer dash
Old Aug 10, 2003 | 11:37 PM
steve83's Avatar
steve83
It's a huge pain. The '93 dash won't fit your firewall very well, and the '93 column won't fit without the big aluminum e-brake pedal bracket that only fits the '92-96 firewall. You can scavenge a LOT of useful parts out of the dash, but don't waste the time trying to swap the dash into your truck. Look thru my signature link.
