Heater valve placement
Old Aug 29, 2014 | 02:45 PM
ungerp's Avatar
ungerp
Installing my heater hoses to the core on my 55. I presume the one from the water pump goes to the bottom inlet on the heater core and the one from the manifold goes to the top. So in which hose does the heater shutoff valve go in the top or bottom hose? I would think the bottom hose from the water pump.
Old Aug 29, 2014 | 04:15 PM
52 Merc's Avatar
52 Merc
Actually, it's the other way around. The water pump pulls the water from the bottom of the radiator and also through the heater core from the intake manifold, just before it goes back to the rad. The shutoff valve should go in the line from the intake so hot water isn't entering the core. The hot water from the intake goes in the bottom of the core and the line back to the pump is the top core fitting.
Old Aug 29, 2014 | 06:23 PM
rhopper's Avatar
rhopper
Wayne's right! Vintage Air told a story awhile back about heater valves in the return line. The suction of the pump would pull the valve open, letting hot water flow through the heater core when the heat was off.
harrythehack
Nov 29, 2018 04:58 PM
Cracker289
Jun 24, 2012 12:04 AM
bamaf150
Dec 12, 2011 06:45 PM
sleep_deprived129
Dec 1, 2011 09:41 PM
hotrod351
Mar 4, 2009 10:55 PM
