Filler tube question
Old Aug 27, 2013 | 05:47 PM
X-70STANG-F150's Avatar
X-70STANG-F150
Should there be a flapper on the fuel fill pipe? I open the fuel door and have an open pipe to the tank. I filled up for the first time and was surprised not to find one.
Old Aug 27, 2013 | 06:00 PM
69cj's Avatar
69cj
You find the flapper on gassers and usually to prevent leaded gas going into unleaded vehicles.
Old Aug 27, 2013 | 06:02 PM
X-70STANG-F150
Good. I was hoping i wasn't missing something that is supposed to be there.
Old Aug 27, 2013 | 06:17 PM
Misky6.0's Avatar
Misky6.0
The "wide mouth" opening also accepts the HIGH flow pump handles available are select truck stops/service stations.. These things will fill-up your tank in no time..
Old Aug 27, 2013 | 06:20 PM
X-70STANG-F150
Are the high flow pumps marked any different?
Old Aug 27, 2013 | 06:22 PM
Misky6.0's Avatar
Misky6.0
I've found some stations have a separate diesel pump "island" - and these usually have the high-flow (see the pic I attached).
I have a local Texaco with the high-flow nozzles - no sign other than it's bigger.
Old Aug 27, 2013 | 06:27 PM
69cj's Avatar
69cj
And if you don't keep the flow rate on the low notch you'd better have a rain coat on that your willing to throw away.
Old Aug 27, 2013 | 06:40 PM
X-70STANG-F150
Thanks for the warning!!!!
Old Aug 28, 2013 | 11:06 AM
cartmanea's Avatar
cartmanea
Do you not have a fuel cap?
Old Aug 28, 2013 | 11:30 AM
X-70STANG-F150
Yeah, there is a twist-on cap. I didn't describe that very well.
Old Aug 28, 2013 | 11:43 AM
run6.0run's Avatar
run6.0run
Good question. Lol
Old Aug 28, 2013 | 01:07 PM
99ExpyProblems's Avatar
99ExpyProblems
I found that out the first time I filled up at one of those. You can't hardly even top the tank off at one of the high flow places. *dunce cap*
Old Aug 28, 2013 | 10:45 PM
bismic's Avatar
bismic
I can fill up at full flow at the big rig pumps w/ the harpoon mod.
Old Aug 28, 2013 | 11:50 PM
Yahiko's Avatar
Yahiko
I take it because I did not take a diesel bath at the big rig
pump on high flow. That I have my tank has the harpoon mod
done already?
Sean
Old Aug 29, 2013 | 05:45 AM
bismic's Avatar
bismic
I would think so.
