Part numbers?
Old Aug 27, 2013 | 05:11 PM
Restlesswildman's Avatar
Restlesswildman
Part numbers?
Is there a list on the forum of what parts are needed for specific maintenance chores on the 6.0 L? As a newbie to the 6.0L it would be nice to have a list of P/N's to review before I order parts or spend hours searching.
I have searched and not found many P/N's listed. It seems that Tousley now known as Autonation White Bear Lake Ford has changed the parts Fische a but. It seems to be less user friendly.
I am getting ready to do ball joints, springs and possible a track bar. I am wanting to know what I need besides the yellow o-ring for the hub. What are the SHOULD replace items when I am there.
I also have to do an oil cooler and have been searching for what all I need to have on hand. I have read comments on an updated cooler from the Ford, but can not locate it on a parts fische.
I read through the Tech Folder looking for a parts list for both the above items and did not find one.
TIA for the help.
Old Aug 27, 2013 | 05:46 PM
diesel_dan's Avatar
diesel_dan
Here's the p/n for the updated cooler:
Oil Cooler Latest Ford (comes w/ updated screen) 3C3Z6A642CA
One thing I'd recommend is doing the order over the phone, the parts guys there are extremely knowledgeable and I got help from them once they understood what I was doing.
One of the tough things about just a list of parts per job, is that there is overlap when say you are doing 3 or 4 things in the same area. So I ended up just building a spreadsheet -- great idea though...
What I found interesting was talking to mechanics who had jobs broken down on an x, y or z basis, that there was overlap in labor hours that they wouldn't acknowledge. I went with a shop that had a $35/hr higher base labor rate, but was conversant enough in what I was doing that they both knew the trick things to do, but the overlap. Their total bill (which they did shoot me an FTE discount) was hundreds of dollars less than the cheaper per/hr shop.
Sorry, going off topic on ya'...
Old Aug 27, 2013 | 07:59 PM
jswartz84's Avatar
jswartz84
3C44 9F836 AC---------------------------------------------------------Accelerator Pedal Assembly
3C3Z 12B637 BA / 1854174C9--------------------------------------Engine Harness (2003/ Early 2004(EBP Sensor Bolted To Thermostat Housing))*
4C3Z 12B637 AA / -----------------------------------------------------Engine Harness (Mid and Late Build 2004)*
4C3Z 12B637 CA
5C3Z 12B637 AA / -----------------------------------------------------Engine Harness (Early Build 2005)*
5C3Z 12B637 BA / 1855214C9---------------------------------------Engine Harness (Late Build 2005/2006/2007(EBP Sensor Bolted To FICM Bracket))*
3C3Z 9D93 AA / 1843796C92 /
1843797C93(Updated Harness)*------I----------------------------njector Wiring Harness (2003(ICP & IPR REAR MOUNTED))*
4C3Z 9D930 AA / 1844137C97--------------------------------------Injector Wiring Harness (2004)*
5C3Z 9D930 AA / 1870390C91--------------------------------------Injector Wiring Harness (2005/2006/2007)*
4C3Z 12B599 ABRM / 4307223R91----------------------------------FICM (Fuel Injection Control Module)*
3C3Z 9E527 ECRM / 1878282C91-----------------------------------Injector: (2003/2004 (04 Built Before 9/23/03))*
4C3Z 9E527 BRM / 1845150C92 -----------------------------------Injector: (2004/2005/2006/2007 (2004 Built On or After 9/23/03))*
3C3Z 9229 AA / 1843682C91 -------------------------------------- Injector O-Ring Kit
3C3Z 9C995 AA / ------------------------------------------------------Injector Hold Downs 18mm heads
3C3Z 6571 AA / --------------------------------------------------------6.0 Valve Seal
3C3Z 6513 AA / --------------------------------------------------------6.0 Valve Spring
3C3Z 6505 AA / --------------------------------------------------------6.0 Exhaust Valve
3C3Z 6507 AA / 1837731C ------------------------------------------6.0 Intake valve
8C3Z 6565 B / ----------------------------------------------------------6.0 Push-Rod
4C3Z 6564 AA-----------------------------------------------------------Combination Dual Valve Rocket Arm
3C3Z 6564 BA-----------------------------------------------------------Intake Valve Rocker Arm
3C3Z 6564 AB-----------------------------------------------------------Exhaust Valve Rocker Arm
4C3Z 6250 AA / ------------------------------------------------------- Camshaft
3C3Z 6D309 AA---------------------------------------------------------Camshaft Bearings
3C3Z 6303 AARM / ---------------------------------------------------- Crankshaft (with bearings)
4C3Z 6108 AA / --------------------------------------------------------Piston w/ Rings and Retainers
1834675C1-------------------------------------------------------------Connecting Rod
8C3Z 6C329 A / ------------------------------------------------------ Roller Lifter Guide
8C3Z 6C329 B / -------------------------------------------------------Roller Lifter Guide (With 4 Lifters)*
3C3Z 6500 AA /--------------------------------------------------------Roller Lifter (Single)84-07 Diesel Engines!)*
3C3Z 6010 BA / ------------------------------------------------------ Engine Block and Bed plate (BARE 18mm Cylinder Head Dowel)*
6C3Z 6010 A / -------------------------------------------------------- Engine Block and Bedplate (BARE 20mm Cylinder Head Dowel)*
3C34 6B033 AB--------------------------------------------------------Engine Mount (Left)*
3C34 6046 AB---------------------------------------------------------Engine Mount (Right)*
3C3Z 6020 CA---------------------------------------------------------Engine Front Cover Gasket (Includes Seal)*
3C3Z 6700 BA---------------------------------------------------------Engine Front Cover Seal
3C3Z 6701 B / --------------------------------------------------------Rear Main Seal
3C3Z 6049 DA / 1872648C91--------------------------------------Cylinder Head
/ 1858473C1----------------------------------------------------------Rocker Boxes
3C3Z 6051 CB / 1847028C96--------------------------------------Head Gasket (18mm)*
4C3Z 6051 EB / 1847100C95--------------------------------------Head Gasket (18mm KIT 2 Gaskets + Stand Pipes + Dowel Pins + Head Bolts)*
6C3Z 6051 AA / 1858190C92--------------------------------------Head Gasket (20mm)*
6C3Z 6051 BA / 1832715C93 -------------------------------------Head Gasket (20mm KIT 2 Gaskets + Stand Pipes + Dowel Pins + Head Bolts)*
3C3Z 6584 AA / 1826703C1---------------------------------------Valve Cover Gaskets (Upper, Lower, + Grommets)*
3C3Z 6584 BA / 1838250C1
1838250C2
W302725 (Ford Hardware PN)-------------------------------------CCV O-ring (Green)*
3C3Z 6A603 AA -------------------------------------------------------CCV (2003 to 9/23/03)*
4C2Z 6A603 AA / -----------------------------------------------------CCV (Positive Crankcase Ventilation)*
4C3Z 6A665 AC /----------------------------------------------------- CCV Adapter (bolts to the top of the rocker cover, CCV hose kit connects to this)
3C3Z 9439 AA / 1836542C1----------------------------------------Intake Manifold Gasket (3C3Z-9433-BE 2 Gaskets + Turbo Hardware + EGR Cooler Gaskets)*
3C3Z 9439 BJ /
6C3Z 9448 A / 1840701c92 ---------------------------------------Exhaust Manifold Gasket
1839905C2-----------------------------------------------------------Intake Elbow (2003/2004)*
1846624C1-----------------------------------------------------------Intake Elbow (2005/2006/2007)*
3C3Z 9P457 AA------------------------------------------------------Intake Elbow Gasket (2003/2004/2005/2006/2007)*
W300014 (Ford Hardware PN)-----------------------------------Intake Elbow Hardware (2005/2006/2007 x4) Needed to swap out 03-04 elbow))*
3C3Z 9C623 AA----------------------------------------------------Air Inlet Duct (Connects to Turbo Inlet)
4C3Z 9601 AA ------------------------------------------------------Air Filter
6C3Z 9C623 A / ---------------------------------------------------Air Cleaner to Turbo Hose
4C3Z 6A603 AA /---------------------------------------------------Breather Box to Air Inlet Hose
3C3Z 6750 AA / 1844444C3-------------------------------------Oil Dipstick (2003/2004/2005) T-Handle)*
6C3Z 6750 A / 1870890C91-------------------------------------Oil Dipstick (2006/2007) Ring Handle)*
4C2Z 6750 AA / 1845110C3-------------------------------------Oil Dipstick (E Series (2004/2005/2006/2007))*
3C3Z 8753 AA------------------------------------------------------Oil Dipstick Blue O-Ring
3C3Z 6881 CA / 1847056C93-----------------------------------Oil Filter Adapter for EARLY 2003 (Build Date Prior to 3/17/2003 NEEDED FOR NEW TURBO FEED LINE)*
3C3Z 6C755 AA----------------------------------------------------Oil Filter Housing Return Tube (Oil Filter Slides Over It)*
3C3Z 6800 A / -----------------------------------------------------Oil Filter Drain Valve (Poppet Valve)*
3C3Z 6766 CA / RACOR RK31821 ------------------------------Oil Filter Cap (Frame Mounted Fuel Filter Cap)*
3C3Z 9G270 AA / 1843057C91----------------------------------Fuel Filter Cap (Engine Mounted)
FL 2016 (Motorcraft) ----------------------------------------------Oil Filter
FD 4616 (Motorcraft) ----------------------------------------------Fuel Filter (Primary/Secondary)*
PFL 2016 (RACOR)-------------------------------------------------Oil Filter
PFF 4616 (RACOR)-------------------------------------------------Fuel Filter (Primary/Secondary)*
1840752C91 (International)-------------------------------------Oil Filter
1847170C92 (International)-------------------------------------Fuel Filter (Primary/Secondary)*
3C3Z 9T289 AA/ 1843061C92-----------------------------------Fuel Filter Housing Return Kit
3C34 9J338 AG-----------------------------------------------------Fuel Bowl Supply / Return Lines
6E7Z 9C082 A / 2589259C91------------------------------------HFCM Drain (Brass Replacement No Tool Required)*
6C3Z 9G282 C /-----------------------------------------------------Frame Mounted Fuel Pump (Horizontal Fuel Conditioning Module)*
4C2Z 9275 AA / -----------------------------------------------------Fuel Sending Unit (In Tank)*
5C3Z 9275 BA
6C3Z 10346 DARM /------------------------------------------------Alternator - 110A (F series)
6C3Z 10346 BARM /------------------------------------------------Alternator - 140A (F series)
3C2Z 6B209 AA / ---------------------------------------------------Belt Tensioner (Single Alternator)*
3C2Z 6B209 BA / ---------------------------------------------------Belt Tensioner (Dual Alternator)*
3C3Z 8620 DB / ----------------------------------------------------F Series Single Alternator Belt
3C3Z 8620 BC / ----------------------------------------------------F Series Dual Alternator Belt
3C3Z 8620 HB / ----------------------------------------------------F Series Aux Alternator Belt
3C3Z 8620 AB / ----------------------------------------------------E Series Single Alternator Belt
3C3Z 8620 BB / ----------------------------------------------------E Series Dual Alternator Belt
3C7Z 8620 AC / ----------------------------------------------------Excursion Alternator Belt
3C3Z 8678 EB/ ---------------------------------------------------- Idler Pulley
3C3Z 12A342 AA / 1836600C1-----------------------------------Long Glow Plug (2003)*
4C3Z 12A342 AA / 1843286C2-----------------------------------Short Glow Plug (2004/2005/2006/2007)*
4C2Z 12A690 BA / 1845695C93---------------------------------Glow Plug Harness (Left)*
4C2Z 12A690 AB / 1845794C9-----------------------------------Glow Plug Harness (Right)*
4C3Z 12B568 AA / -------------------------------------------------Glow plug connector harness assembly
3C3Z 12A690 BA / -------------------------------------------------Glow Plug Bus Bars (Right(2003))*
3C3Z 12A690 AA / -------------------------------------------------Glow Plug Bus Bars (Left(2003))*
YC3Z 12B533 AA / 1828565C1-----------------------------------Glow Plug Module
3C3Z 9T517 AG / 1854267C94----------------------------------"BLUE SPRING" Fuel Pressure Regulator
6E7Z 9C165 B / 1854267C94 -----------------------------------"BLUE SPRING" Fuel Pressure Regulator W/O COVER!
W302472 (Ford Hardware PN)------------------------------------6.4 Banjo Bolts (You will need 2)*
W303659 (Ford Hardware PN)------------------------------------6.4 Banjo Washers (You will need 4)*
F81Z 9278 AA /------------------------------------------------------Oil Pressure Sender
SW6053 / 1836537C91--------------------------------------------ECT/EOT Sensor
DY984 / 1836539C91 ----------------------------------------------IAT Sensor
3C3Z 9C968 AA / 1839437C95-----------------------------------IPR Solenoid (2003/2004)*
5C3Z 9C968 CA / 1842428C92-----------------------------------IPR Solenoid (2005/2006/2007)*
3C3Z 9H529 A / 1888696C93-------------------------------------IPR Screen/O-Ring Update Kit (500 Micron)*
6E7Z 12A690 DA-----------------------------------------------------IPR Pigtail (May be metal clip style or 2 plastic tab style) Use this for IPR test jumper))*
3C3Z 9F838 EA / 1845274C92------------------------------------ICP SENSOR (2003/2004)*
4C3Z 9F838 A / 1845428C92-------------------------------------ICP SENSOR (2005/2006/2007)*
5C3Z 12224 A /------------------------------------------------------ICP/EBP Pigtail
3L3Z 12B579 ARM / ------------------------------------------------MAF Sensor (Mass Air Flow)*
4X2Z 9L474 AA------------------------------------------------------MAP Sensor (Manifold Absolute Pressure)*
3C3Z 6C315 AA / 1828345C91-----------------------------------Crank Sensor
BC3Z 12K073 A / 1835985C92-----------------------------------Cam Sensor
4C3Z 9J460 A / 18050353C1-------------------------------------EPB Sensor (2003/2004)*
5C3Z 9J460 A / 1850352C2--------------------------------------EPB Sensor (2005/2006/2007)*
4C3Z 9F452 A / 1846491C91-------------------------------------EGR Valve (2003/2004)*
5C3Z 9F452 AA / 1846490C91-----------------------------------EGR Valve (2005/2006/2007)*
3C3Z 9P455 AB / 1840778C32-----------------------------------EGR Valve O- Ring
F81Z A784 BB--------------------------------------------------------EGR Vacuum Tube
3C3Z 9P456 A / 1846491C91-------------------------------------EGR Cooler (2003/2004)*
4C3Z 9P456 AJ / 1845145C96------------------------------------EGR Cooler (2005/2006/2007)*
4C4Z 8592 AA / 1837845C2 --------------------------------------EGR Cooler Hose (Motorcraft # RH153)
W300022 (Ford Hardware PN)------------------------------------EGR Cooler Supply Ports Housing Bolts
4C4Z 8592 AA ------------------------------------------------------Blue Updated Water Outlet Connector
6C3Z 8A080 B / ----------------------------------------------------Degas Bottle
9C3Z 8101 B / -----------------------------------------------------Degas Bottle Cap
F81Z 8287 EA / 1824400C---------------------------------------Radiator Hose Clamp (V-Band)*
3C34 8287 BA
3C3Z 8260 AG------------------------------------------------------Upper Radiator Hose
5C3Z 8286 DH------------------------------------------------------Lower Radiator Hose
4C3Z 8A616 AA /---------------------------------------------------Fan Clutch
3C3Z 8600 AB / ---------------------------------------------------Cooling Fan
3C3Z 8501 AB / ---------------------------------------------------Water Pump (2003/2004 Early Build up to 9/30/03)*
4C3Z 8501 AC / ---------------------------------------------------Water Pump (Late Build 9/30/03 and after 2004)2005/2006/2007))*
3C3Z 8575 AA /1839304C92------------------------------------Thermostat (190°F)
4C4Z 8575 AA / 1837971C91-----------------------------------Thermostat (190°F)
3C3Z 8255 AA /----------------------------------------------------Thermostat O-Ring
3C3Z 9A543 AARM / 5010106R93------------------------------HPOP(High Pressure Oil Pump) 2003/Early 2004))*
4C3Z 9A543 AARM (Late Build 2004)*
5C4Z 9A543 C / 5010119R92-----------------------------------HPOP(High Pressure Oil Pump) 2005/2006/2007))*
W301383 (Ford Hardware PN) -------------------------------- High pressure rail hold down bolts
W300049 (Ford Hardware PN)---------------------------------10mm Hold Down Nut (Dipstick to Valve Cover, Ficm Hold Downs etc.)
3C3Z 6C683 AB / 1838526C2-----------------------------------HPOP Updated Screen
3C3Z 6619 EA / ---------------------------------------------------HPOP Cover Gasket
/ 839187C3---------------------------------------------------------HPOP Cover (2003/2004)*
5C3Z 9G805 C / 1845411C1------------------------------------HPOP Cover (2005/2006/2007)*
3C3Z 6608 B /-----------------------------------------------------Ford 6.0 Oil Pump (Production Date Before 9/22/03 F250, F350, F450, F550/International VT365)*
4C3Z 6608 B / ----------------------------------------------------Ford 6.0 Oil Pump (Production Date After 9/22/03 F250, F350, F450, F550/International VT365)
3C3Z 6608 BA / ---------------------------------------------------Oil Pump Gears
4C3Z 9B246 F / 1879930C93-----------------------------------STC Fitting (HPOP (2004.5/2005/2006/2007))*
5C3Z 6K632 A / 1844127C91-----------------------------------Turbo Assembly
5C3Z 9G489 ACRM------------------------------------------------Turbo Center Section (Rotating Assembly)*
3C3Z-6N639-BA/1846207C1----------------------------------- Turbo Pedestal to 9-22-03 (2003 pedestal)
5c3Z-6N639-AA / -------------------------------------------------Turbo Pedestal from 9-22-03 (2004.25+)
5C3Z 6F089 BA / --------------------------------------------------VGT Solenoid
1837984C91------------------------------------------------------Turbine Wheel + Shaft
3C3Z 6K854 DA/ --------------------------------------------------Exhaust "Y Pipe"
3C3Z 6K854 AA / -------------------------------------------------Up-Pipe
3C3Z 6N640 AA / -------------------------------------------------Up-Pipe to Y-Pipe gasket
F81Z 8287 EA / ---------------------------------------------------Turbo Up Pipe Clamp
W300013 (Ford Hardware PN)---------------------------------Y-Pipe Bolt (Long 4 Required)*
W300006 (Ford Hardware PN)---------------------------------Y-Pipe Bolt (Short 2 Required)*
W300051 (Ford Hardware PN)---------------------------------Y-Pipe nut (6 Required)*
3C3Z 9T514 AG / 1840053C96 --------------------------------Turbo Hardware "Mounting" Kit
4C4Z 9V424 AA / 1870713C91---------------------------------Turbo Reconditioning Kit with Hardware
6C3Z 9T515 A / 1876071C91-----------------------------------Updated Turbo Drain
3C3Z 9T516 A / 1845287C96-----------------------------------Updated Turbo Feed
W300012 (Ford Hardware PN)---------------------------------Turbo Drain Orings
3C3Z 9t514 A / ----------------------------------------------------Old Braided Turbo Feed
3C3Z 6C885 A /----------------------------------------------------Turbo Unison Ring
6C3Z 6C640 AA / -------------------------------------------------Cold Side Inter-cooler Tube (2003/2004) Replaces Plastic on 2005 and up))*
6C2Z 6K786 AA /--------------------------------------------------Clamp
6C3Z 6K786 CA /--------------------------------------------------Clamp
6C3Z 6C640 C /---------------------------------------------------Turbo Hose - Shorter Hose (Blue) or (Red-Orange) - Before 10-14-2004
6C3Z 6C640 A /---------------------------------------------------Turbo Hose - Longer Hose (Red-Orange) - From 10-14-2004
6C3Z 6C640 B /---------------------------------------------------CAC Hose (Red-Orange)
5C3Z 6K769 BA /--------------------------------------------------Metal Duct-Dual Generator - Shorter Duct - From 10-14-2004
6C3Z 6K769 A /---------------------------------------------------Metal Duct-Dual Generator - Longer Duct - Before 10-14-2004
5C3Z 6K769 AA /--------------------------------------------------Metal Duct-Single Generator - Shorter Duct - From 10-14-2004
6C3Z 6K769 B /---------------------------------------------------Metal Duct-Single Generator - Longer Duct - Before 10-14-2004
I got this list from .org
Old Aug 28, 2013 | 06:09 PM
Restlesswildman
Thank you so much for the parts list!!!! This is awesome!
Old Aug 29, 2013 | 12:45 AM
jswartz84's Avatar
jswartz84
Sean cleaned up that list and put it in a pdf us. Here is the link.
http://www.washingtonspeaksout.org/D...0list%2001.pdf
Old Oct 29, 2013 | 07:21 PM
greenheads's Avatar
greenheads
Bump trying to move this thread to the top so I can find it on my CPU.
Old Oct 29, 2013 | 07:30 PM
99ExpyProblems's Avatar
99ExpyProblems
Lol, just save it to your browser favorites.
Old Oct 29, 2013 | 07:45 PM
greenheads's Avatar
greenheads
It is now but my phone and CPU don't sync so this was the quickest way find it. It's bad when your phone and CPU are both on FTE at the same time
Old Oct 29, 2013 | 11:01 PM
jswartz84's Avatar
jswartz84
Sticky????
Old Oct 30, 2013 | 05:00 AM
npccpartsman's Avatar
npccpartsman
This is EXCELLENT advice. There are areas that are very gray when it comes to 6.0's and trucks (wiring harnesses, rocker boxes, heads/gaskets) and a good parts guy can get you out of a very expensive bill. Have your VIN handy.
Old Apr 11, 2014 | 04:56 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Bump (for you guys who haven't seen this list before)
Old Apr 11, 2014 | 08:00 PM
KDAVID1's Avatar
KDAVID1
Subscribed
Old Nov 19, 2014 | 09:44 PM
happscrap's Avatar
happscrap
Subscribed
Old Jan 24, 2015 | 07:57 AM
KDAVID1's Avatar
KDAVID1
TIA for the help.
Subscribed
Old May 11, 2015 | 05:04 PM
Rusty Axlerod
Sorry, wrong thread.
